I have written a UI automation script in Instruments and Its working perfectly. Now I want to know is there any way that I simply double click on script and Its start working or at least I don't need to run Xcode for running the script.
Asked
Active
Viewed 105 times
possible duplicate of [Can the UI Automation instrument be run from the command line?](http://stackoverflow.com/questions/4191945/can-the-ui-automation-instrument-be-run-from-the-command-line) – Sulthan May 26 '14 at 12:44
instruments -w 1.device_id -t /Developer/Platforms/iPhoneOS.platform/Developer/Library/Instruments/PlugIns/AutomationInstrument.bundle/Contents/Resources/Automation.tracetemplate 2.application -e UIASCRIPT 3.script -e UI-ARESULTSPATH 4.results path
The ones marked with 1. 2. 3. 4. are the variables that you type. Use this code, put in your device id, app, script and result path and run the whole line in Terminal
Vlad.D
- 127
- 9
for this i need to build the project. lets say i have only ".ipa" file and script can i run script? – Omer Obaid May 26 '14 at 12:57
Yes you can run the script. At 2.applicatian you can specify the path to the application or command to launch it. – Vlad.D May 27 '14 at 07:20
