I have a new GPU is has 16 GB of RAM and I downloaded the wallet so I can set upon mining a block, but I do not know what I am doing. Can I get some help?
Asked
Active
Viewed 46 times
First, using a GPU for Monero mining is not particularly wise. Monero's mining algorithm, RandomX, favors CPUs.
Second, you'll get much better hashrate using a dedicated miner (e.g. XMRig) than using the wallet.
Third, I suggest you review the r/MoneroMining FAQ.
jtgrassie
- 19,601
- 4
- 17
- 54
