I was reading this question. Im not mathematician but I like a lot and in spare time I try to learn something.
My question is: reading the previous question of the link I understand (if Im not wrong) that summation and integral are the same thing but in different type or measure, countable measure and uncountable measure or so.
So the mechanic is the same the only that changes is measure. So, why use different notation or simbology for the same generalized thing? Thank you.
    Historically, they were not considered the same (though the symbol for integral is initially an $S$ for sum), the link has become much clearer with Lebesgue integral (the sum is the integral wrt a discrete measure). Apart from that, I agree with 5xum, no need to introduce at lower levels a notation that is explained by much higher mathematics. – Jean-Claude Arbaut Sep 02 '14 at 07:36
  • The integral is quite a specific sort of summation, so instead of writing out a long summation (including limits too actually) to describe an integral, why not just use a shorter notation? Especially since integrals are all over the place in mathematics. – Sheheryar Zaidi Sep 02 '14 at 07:36
  • @SheheryarZaidi Actually, if you introduce the correct measure, integrating wrt that measure is exactly the same as summing. No limits involved. I believe that is what OP is asking. – 5xum Sep 02 '14 at 07:39
  • $$\int_a^bf(x)~dx~ = ~\lim_{n\to\infty}~\frac1n\cdot\sum_{k=0}^{(b-a)n}f\bigg(a+\frac kn\bigg)~ = ~f^{(-1)}(b)-f^{(-1)}(a).$$ – Lucian Sep 02 '14 at 19:08
Shortest answer: Because mathematics is useful.
Short answer: I see no reason to use a unified notation just because there exists some highly theoretical framework in which two things are identical.
Longer answer:
The purpose of mathematical notation is an optimal way of conveying information from the author to the reader. Since people generally start to learn sums and integrals long before they learn measure theory, it is (at that point) completely natural that two notations are introduced.
Later, when the two things are shown to be two sides of one coin, you can simply weight the pros and cons of changing notation:
Pros:
  • The notation is now more in tune with measure theory
Cons:
  • The notation is harder to learn
  • The new notation requires mathematitians to "unlearn" the old notation from their subconsciousness (or else it will cause them to "think" more slowly since they will have to translate)
  • The new notation confuses engineers and other professions which use mathematics without going to the deep theoretical stuff. It also reinforces the view by these people that mathematics is mental masturbation for its own purpose.
Another point:
Do you really think using only integral notation will be any better? Let us say I have a sequence $a_n$ and a function $f(x)$. If I want to integrate the function and sum the sequence, I write
Let $a_n$ be a sequence and $f$ a real function. Then we calculate $$\int_a^b f(x)dx + \sum_k^l a_n$$
And it is immediatelly clear what is happening. In your case, I would have to say
Let $a$ be a function from $\mathbb N$ to $\mathbb R$ and $f$ be a function from $\mathbb R$ to $\mathbb R$ and let $\mu$ be the Lebesgue measure on $\mathbb R$ and $\lambda$ the counting measure on $\mathbb R$. Then we calculate $$\int fd\mu + \int ad\lambda$$
Is the second way really better than the first?
5xum
  • 126,227
  • 135
  • 211
  • Ok, I understand the practical issues with tradition, but tradition isnt exactly science, more the opposite to science. Comes to my mind the thing that happen with roman numbers. I know is a difference but I dont think that defend a tradition maybe good in any way. –  Sep 02 '14 at 07:43
    My argument has nothing to do with tradition. It has to do with practicality. You cannot teach measure theory to 15 year olds, so you must introduce two notations. It is then impractical to unify the two theories as it brings more harm than good. – 5xum Sep 02 '14 at 07:44
  • @5xum You seem to say that these symbols are the same. But in my point of view they are similar but not the same. A simple example :$$\int_0^1x \text{ and} \sum_0^1x$$ Same formula inside $x$ same boundries $0$ and $1$ but you have : $$\int_0^1x=\frac{1}{2}\ne1=\sum_0^1x$$ Did I miss something? – GuiguiDt Sep 02 '14 at 07:45
  • @Deuteu Where did I say that the symbols are the same? – 5xum Sep 02 '14 at 07:47
  • @Deuteu I agree, the symbols are different. I am saying that it is not practical to use one notation for something that most mathematics using people consider two different things. – 5xum Sep 02 '14 at 07:47
  • I dont think so.I think anyone can understand easily measure theory... more if it is as young as a child. And you dont need to teach measure if you change notation, just using countable measure, no need to explain this thing if you dont want. Or maybe if not needed to declare a different measure the standard must be supposed as the countable. Just some thoughts. (I cant make paragraphs in this text editor... enter key just close the edit :S) –  Sep 02 '14 at 07:48
    @Masacroso From time to time, there are people who try to teach crazy things to young pupils. There have been "mathématiques modernes" in France, following more or less the same in the USA. It was a huge mistake, with dramatic consequences on math education. But that won't prevent (some) people to think that a given subject from higher mathematics should be taught early. It's simply that mathematicians are not necessarily good teachers (I mean, they are usually good at their level, not for the young) – Jean-Claude Arbaut Sep 02 '14 at 07:51
  • @Masacroso It is completely useless for an engineer to know measure theory. It is useful for him to know integrals and sums. Therefore, in order to introduce your notation, you would need to teach an engineer something that will be completely useless to him. – 5xum Sep 02 '14 at 07:51
  • @5xum The fact that your answer wasn't "they are different" let me think that we can consider them the same. And for me as I said there are totally different so I wanted not to be convinced that they are the same but to try to understand how some people assimilate them, as your sentence "there exists some highly theoretical framework in which two things are identical" let me presume it. – GuiguiDt Sep 02 '14 at 07:53
  • @denteu Summing a sequence is the same as integrating the sequence wrt a counting measure on $\mathbb N$. In that framework, summing is integration. – 5xum Sep 02 '14 at 07:59
    @Masacroso See my last edit to my answer. Would you say the first or the second way is easier to understand? – 5xum Sep 02 '14 at 07:59
  • @5xum I understand the point. I think my idea just maybe interesting if there is some framework where are a lot of summations and integrals or where they are linked strongly in the matter, in other cases isnt so justified. –  Sep 02 '14 at 08:02
  • @5xum Ok, thanks for the precision. I was stuck in integral on continuous. – GuiguiDt Sep 02 '14 at 08:07
    @Masacroso Sure, I agree there may be some case where using integral notation for summing is useful. But in most real world cases, using two notations is much more practical. – 5xum Sep 02 '14 at 08:07
If you need to, you can think of the sum notation as a convenient notation for some common cases in which the full machinery of integration and measure theory is unnecessary, and where a more elementary approach is possible.
The fact that these elementary ideas are also encompassed within the framework of integration, and that the ideas of measure can unify the treatment, for example, of discrete, continuous and mixed distributions is an illustration of the power of the more general point of view. But this does not invalidate the elementary approach for those cases in which it works.
Mark Bennet
  • 101,769
