This is 1.22a in Pugh's Real Mathematical Analysis (p. 44):
Given $\epsilon > 0$, show that the unit disc contains finitely many dyadic squares whose total area exceeds $\pi - \epsilon$, and which intersect each other only along their boundaries.
The desired result goes against my intuition: It seems that I should be able to fit as many squares as I want inside the circle, assuming the squares are small enough.
To try to get an idea of what was going on, I started filling the first quadrant with squares viz dyadic squares along the $x$-axis: $[0, 1/2]\times[0,1/2], [2/4, 3/4]\times[0, 1/4], [6/8, 7/8]\times[0, 1/8], \ldots$ I figured that, if only a finite number fit inside, then eventually the corner furthest from the origin would fall outside the circle i.e., its distance would be greater than $1$. And so I calculated
$$\lim_{n\rightarrow \infty} \sqrt{\left( \sum_{k=1}^n \frac{1}{2^k}\right)^2+\left( \frac{1}{2^n}\right)^2}=1$$
which suggests that, indeed, I can fit as many dyadic squares as I want in this direction and so why not in any direction?
I'm guessing I'm missing something here. Could someone please shed some light? on what I'm misunderstanding, how else I might start, or both? Beyond what I've tried, I'm not sure I have any idea where to start with this problem. (Not to mention the one that follows, in which the squares are disjoint.)
