40
I've run into a strange situation while trying to apply Integration By Parts, and I can't seem to come up with an explanation. I start with the following equation:
$$\int \frac{1}{f} \frac{df}{dx} dx$$
I let:
$$u = \frac{1}{f} \text{ and } dv = \frac{df}{dx} dx$$
Then I find:
$$du = -\frac{1}{f^2} \frac{df}{dx} dx \text{ and } v = f$$
I can then substitute into the usual IBP formula:
$$\int udv = uv - \int v du$$
$$\int \frac{1}{f} \frac{df}{dx} dx = \frac{1}{f} f - \int f \left(-\frac{1}{f^2} \frac{df}{dx}\right) dx$$
$$\int \frac{1}{f} \frac{df}{dx} dx = 1 + \int \frac{1}{f} \frac{df}{dx} dx$$
Then subtracting the integral from both sides, I've now shown that:
$$0 = 1$$
Obviously there must be a problem in my derivation here... What wrong assumption have I made, or what error have I made? I'm baffled.
Nate Eldredge
  • 101,664
  • 53
    There is no mistake, and it does not prove 0 = 1. It proves only that 0 = 1 + $C$ for some constant $C$. An indefinite integral always has a constant of integration to be taken into account. You may have noticed in Calculus 2 that you come up with the exact same kind of result when you integrate by parts the expression $\ln (x+1)$ directly without intermediate $u$-substition vs. doing it with intermediate $u$-substition, as another example. – Joseph Myers May 23 '14 at 05:44
    The problem is using antiderivatives (poorly called "indefinite integrals") as if they were integrals. – Martin Argerami May 23 '14 at 05:53
  • 11
    0 does equal 1 up to an additive constant – Tim Seguine May 23 '14 at 20:48
  • 29
    I'd call on several students, one after another, and demand that they tell me what is $\displaystyle\int\dfrac{dx}{x}$, $\displaystyle\int\dfrac{du}{u}$, $\displaystyle\int\dfrac{dz}{z}$, $\displaystyle\int\dfrac{da}{a}$, and then, as the clincher, I'd ask about $\displaystyle\int\dfrac{d(\text{cabin})}{\text{cabin}}$. Some of them would grin amiably and shout out "log cabin", and they were surprised when I told them that I didn't agree. The right answer (as I learned when I was learning calculus) is "house-boat", "log cabin plus sea". – user3459110 May 24 '14 at 05:59
  • @AwalGarg very nice! ;) – An old man in the sea. Sep 01 '16 at 08:18
  • My answer here satisfactorily explains the situation using only what a beginning student knows about indefinite integrals. – Pedro Apr 21 '24 at 23:57
5 Answers5
85
Hint: Constant of integration.
8
You have correctly derived that $0 = 1$... modulo constants.
Antiderivatives are only well-defined modulo constants*; e.g. both $x$ and $x+1$ are antiderivatives (with respect to $x$) of $1$. The equation you wrote is implicitly only meant to be an equation modulo constants; that is, the two sides of the equation don't have to be equal: they're allowed to differ by a constant.
This is traditionally worked around by adding a "constant of integration" in an ad-hoc manner rather than trying to introduce modular arithmetic. This ad-hoc fix can be tricky to get right in a nontrivial algebraic calculation if you don't fully understand what's going on, as your calculation shows.
When you cancel out the two copies of $\int\frac{1}{f} \frac{df}{dx} \, dx$, that doesn't get rid of the fact that the equation is still only meant to hold modulo constants: you've merely eliminated your mental cue (the presence of an antiderivative) to remind you of that fact.
*: Technically, I should say "locally constant functions in the integration variable" rather than "constants"
This line $$\int \frac{1}{f} \frac{df}{dx} dx = \frac{1}{f} f - \int f \left(-\frac{1}{f^2} \frac{df}{dx}\right) dx$$ should be $$\int_a^b \frac{1}{f} \frac{df}{dx} dx = \left[\frac{1}{f} f\right]_a^b - \int_a^b f \left(-\frac{1}{f^2} \frac{df}{dx}\right) dx$$ so $$\int_a^b \frac{1}{f} \frac{df}{dx} dx = \left[1\right]_a^b - \int_a^b f \left(-\frac{1}{f^2} \frac{df}{dx}\right) dx$$ and $\left[1\right]_a^b=0$
Fabien
  • 2,988
The problem here is that when you applied the By Parts Formula $$uv-\int \frac{du}{dx}vdv $$
you took $u=\frac 1f$ and $dv=\frac {df}{dx}dx$ Now when you use by parts formula your first task is to get $v$ and for that you need to do this $\int dv$, right? You have done all righty, but the problem comes when you write $\int df =f$ Here you also need to add the constant C, Or your proof will get pretty much messed up. In the end where you got $0=1$ , you are lacking that $C$ in this equation here, when you do antiderivatives you can't just provide one answer.If you write $\int df=f$ only then you are only getting one of the infinite solutions because $\frac {d}{df}(f)=1$ but $\frac {d}{df}(f+2)$ is also 1, infact take the derivative of $f+c$ (w.r.t f) where $C$ is any constant, you will always end up with 1.So I guess that's the error.Next time be careful with constants.
Hope It answered your question.
As an exercise, look at this proof of $0=1$
Differentiate both sides $wrt $ $x$
$0=0$
Which is true, hence proved.
If you can find the error here, so you can in your above question.
evil999man
  • 6,088
  • This isn't really an accurate analogy; every step of the proof in the OP is a reversible one. –  May 24 '14 at 11:50
  • @Hurkyl Not perfectly accurate but trying to disprove it, he will find the word : arbitrary constant. – evil999man May 24 '14 at 11:51
