I want to find an group-isomorphism $$ \psi : (\mathbb{Z}/8\mathbb{Z},+) \longrightarrow \mathbb{F}_9^\times $$ which should be used to multiply elements in $\mathbb{F}_9$ or to find the inverse element in an easy way.
Edit: Is it right that $\mathbb{F}_9^\times=\mathbb{F}_9\setminus \left\lbrace0\right\rbrace$? – Mar 29 '14 at 00:51
Yes. Start by finding a generator for the multiplicative group of the field (i.e. an element of order 8) – Seth Mar 29 '14 at 00:53
2$X+2$ and $2X+1$ are generators. – Mar 29 '14 at 00:55
Chris, $X+2$ and $2X+1$ are not elements of $\Bbb{F}_9$ unless you specify a polynomial equation satisfied by $X$. – Jyrki Lahtonen Mar 29 '14 at 07:17
If you know generators of ${\mathbb F}_9^\times$ then you have solved the problem already. – Derek Holt Mar 29 '14 at 09:40
@Eppo, that was a bit sloppy editing. $\Bbb{Z}_8$ is not a subgroup of $\Bbb{Z}$, so the notation $\Bbb{Z}/\Bbb{Z}_8$ was gibberish. Whoever approved of that edit should be more careful! – Jyrki Lahtonen Mar 29 '14 at 10:03
@JyrkiLahtonen, absolutely! Sorry folks, I was rather tired when I made that edit... – User12345 Mar 29 '14 at 12:31
No harm, @Eppo. And I didn't spot the error in my first reading :-) – Jyrki Lahtonen Mar 29 '14 at 12:33
As Seth and Pedro indicated the existence of such an isomorphism follows from (and is equivalent to) the cyclicity of the multiplicative group $\Bbb{F}_9^*$. To exhibit an explicit isomorphism you need to specify a construction of $\Bbb{F}_9$ and find a generator of the multiplicative group (aka a primitive element).
Elements of order $8$ are zeros of the cyclotomic polynomial $\phi_8(x)=x^4+1$. As we are working modulo $3$, we can factor it as follows $$ \begin{aligned} x^4+1&=x^4+4=(x^4+4x^2+4)-4x^2\\ &=(x^2+2)^2-(2x)^2=(x^2+2-2x)(x^2+2+2x)\\ &=(x^2-x-1)(x^2+x-1). \end{aligned} $$ So, if we identify $\Bbb{F}_9$ with $\Bbb{Z}_3[x]/\langle x^2-x-1\rangle$, then the coset $\alpha=x+\langle x^2-x-1\rangle$ will be a generator.
The desired isomorphism $\psi:(\Bbb{Z}_8,+)\to (\Bbb{F}_9^*,\cdot)$ is given by $$ \psi(\overline{n})=\alpha^n $$ for all $n=0,1,\ldots,7$. This comes to the following: $$ \begin{array}{c|ccc|c} n&\psi(\overline{n})&&n&\psi(\overline{n})\\ \hline 0&1&&1&\alpha\\ 2&\alpha^2=\alpha+1&&3&\alpha^3=\alpha^2+\alpha=2\alpha+1\\ 4&\alpha^4=2&&5&\alpha^5=2\alpha\\ 6&\alpha^6=2\alpha^2=2\alpha+2&&7&\alpha^7=\alpha+2 \end{array} $$ Here I used the equation $\alpha^2=\alpha+1$ repeatedly. Note also that $\alpha^4=2=-1$, so $\alpha^{4+j}=-\alpha^j$ for all $j$. As a final check we do that $$ \alpha^8=\alpha\cdot\alpha^7=\alpha(\alpha+2)=\alpha^2+2\alpha=3\alpha+1=1 $$ as it should.
The way to use this in finding products and inverses is to treat the inverse of $\psi$ as a logarithm, i.e. a mapping that transforms multiplication in $\Bbb{F}_9$ into addition in $\Bbb{Z}_8$. For example (read the above table from right to left) $$ (\alpha+2)(\alpha+1)=\alpha^7\cdot\alpha^2=\alpha^9=\alpha^{8+1}=\alpha, $$ and $$ (\alpha+1)^{-1}=(\alpha^2)^{-1}=\alpha^{-2}=\alpha^{8-2}=\alpha^6=2\alpha+2. $$
You mentioned that you had found $x+2=x-1$ and $2x+1$ to be generators of $\Bbb{F}_9^*$. That may be true, but to make that meaningful you need to specify the minimal polynomial of $x$. Above I used the minimal polynomial $x^2-x-1$, and $\alpha$ was one of its zeros ($\alpha^3=2\alpha+1$ being the other. If a cyclic group of order $8$ is generated by an element $c$, then $c^m$ is also a generator iff $\gcd(m,8)=1$. So here any of $\alpha$, $\alpha^3$, $\alpha^5$ and $\alpha^7$ is a generator. Not surprisingly those are the zeros of $x^4+1$ in this copy of $\Bbb{F}_9$.
Changing the irreducible polynomial always changes the scene. Your copy of $\Bbb{F}_9$ is $\Bbb{Z}_3[x]/\langle x^2+1\rangle$. Because $x^2+1\mid x^4-1$ in this case $x+\langle x^2+1\rangle$ will not work as a generator. If we let $\beta=x+\langle x^2+1\rangle$, then for $\alpha=\beta+2$ (that you might call $x+2$ even though that abuses notation slightly) we get $$ 0+\langle x^2+1\rangle =(x^2+1)+\langle x^2+1\rangle=(\alpha+1)^2+1=\alpha^2+2\alpha+2=\alpha^2-\alpha-1. $$ Thus $x^2-x-1$ is a minimal polynomial of $\alpha$. In terms of $\beta$ the above the homomorphism looks like $$ \begin{array}{c|ccc|c} n&\psi(\overline{n})&&n&\psi(\overline{n})\\ \hline 0&1&&1&\beta+1\\ 2&(\beta+1)^2=2\beta&&3&(\beta+1)^3=2\beta^2+2\beta=2\beta+1\\ 4&(\beta+1)^4=2&&5&(\beta+1)^5=2\beta+2\\ 6&(\beta+1)^6=\beta&&7&(\beta+1)^7=\beta+2 \end{array} $$ All the elements on the right column ($\beta+1,2\beta+1,2\beta+2,\beta+2$) can take the role of the generator. Thus you get four different such isomorphisms $\psi$. Each will work equally well as the inverse of a discrete logarithm.
- 140,891
See this answer for examples of discrete logarithms in fields $\Bbb{F}8$ and $\Bbb{F}{16}$. – Jyrki Lahtonen Mar 29 '14 at 07:24
Thank you Jyrki for your answer! My polynomial is $X^2+1$. Does it work the same way as your suggestion respectively would the isomorphism be the same? And I could choose $\alpha=X+2$ or $\alpha=2X+1$. – Mar 29 '14 at 10:38
@chris: I added an example reflecting $\alpha=X+1$. If you precompose that with $\overline{n}\mapsto \overline{-n}$ you get what $\alpha=X+2$ would give you. Precomposing with $\overline{n}\mapsto \overline{\pm3n}$ gives the other alternatives. – Jyrki Lahtonen Mar 29 '14 at 11:13
1And so the new isomorphism $\psi:(\Bbb{Z}_8,+)\to (\Bbb{F}_9^*,\cdot)$ is given by $$ \psi(\overline{n})={(\beta+1)}^n $$ for all $n=0,1,\ldots,7$. Is this right? – Mar 29 '14 at 11:24
Correct. Sorry about not making that clear. You can use any generator in place of $\beta+1$ in that formula. If you proved that $\beta+2$ is a generator, you can use $\psi(\overline{n})=(\beta+2)^n$ instead. – Jyrki Lahtonen Mar 29 '14 at 11:26
2I have one more question: When I take the polynomial $X^2+1$ it has one zero $\alpha$ with $\alpha^2=-1=2$. Then it follows that $\mathbb{F}_9=\left\lbrace 0,1,2,\alpha,\alpha+1, \alpha+2,2\alpha,2\alpha+1,2\alpha+2 \right\rbrace$. But $\alpha+2$ and $2\alpha+1$ are the only elements with order $8$ which generate $\mathbb{F}_9^\times$. The other elements $2\alpha+2,\alpha+1,2\alpha,\alpha$ have only order $4$. Why anybody speaks about $4$ generators with order $8$? – Mar 29 '14 at 23:05
The problem is that $\mathbb{Z}/8\mathbb{Z}$ has $4$ generators of order $8$ so I don't really understand how to define the isomporphism. – Mar 29 '14 at 23:06
@chris: Check your calculations. Only $\alpha$ and $-\alpha=2\alpha$ have order $4$. As $\alpha+2$ is of order 8, so is $(\alpha+2)^j$ for any odd $j$. $(\alpha+2)^3=2\alpha+2$ and $(\alpha+2)^7=\alpha+1$ are the other two order eight elements. – Jyrki Lahtonen Mar 30 '14 at 05:25
It suffices you show the group of units of any finite field is cyclic. In fact, any finite subgroup of the group of units of any field is cyclic: $x^d=1$ has at most $d$ solutions in any finite subgroups of $F^\times$, which means any finite subgroups has at most one cyclic subgroup of order $d$.
- 125,149
- 19
- 236
- 403
I don't get how this answers my question. I know that it is cyclic and I already listed the generators. The problem is how to find the isomorphism and to use it. – Mar 29 '14 at 01:19
2Haven't you proven any two cyclic subgroups of the same order are isomorphic? Map a generator to the other. – Pedro Mar 29 '14 at 01:37
