I'm trying to find an example of a ring without identity that does not contain any maximal ideal.
Help me some hints.
Watson
  • 24,404
Truong
  • 4,332
    Since you don't insist that there is an identity, just take an abelian group and define all products to be 0. This is a ring without identity and any subgroup is an ideal. So an abelian group that contains no maximal proper subgroup would be an example. – KCd Dec 25 '13 at 05:46
  • Continuing with KCd's remark, consider the abelian group $\mathbb{Q}$. – Prism Dec 25 '13 at 08:35
  • I would try to reproduce the properties of a field. What happens if you have ax=c always having a solution? If this doesn't imply identity then we have only trivial ideals. – Jacob Wakem Mar 16 '14 at 22:08
Take an abelian group without maximal subgroups, like $(\Bbb Q,+)$, and the zero multiplication, that is, $xy=0$ for any $x,y$.
  • I've posted this trivial example in order to prevent future possible trivial questions on this theme. –  Dec 25 '13 at 12:26
Another example can be found in here http://sierra.nmsu.edu/morandi/notes/NoMaxIdeals.pdf
Truong
  • 4,332
