Hopefully this a short question.
$u(t)$ is the Unit step function or the Heaviside function. $a$>0
Solving using the basic definition, $$F[x(t)]=\int_{-\infty}^{\infty}e^{-at}u(t)e^{-iwt}$$ we get $$F[x(t)]=\frac{1}{iw+a}$$ If we were to start from the Fourier transform of $u(t)$ $$F[x(t)]=\frac{1}{iw}+\pi\delta(w)$$ and use the frequency shifting property of $F[e^{-at}x(t)]=X(iw+a)$, ($X(iw)$ is the FT of $x(t)$)
we get $$F[x(t)]=\frac{1}{iw+a}+\pi\delta(w+a)$$
I first assumed the discrepancy arose due to unwillingness to deal with delta functions in a common transform. but that does not really explain why i haven't seen it literally anywhere.
If there is a alternative explanation, please share.
Also this integral $F[x(t)]=\int_{-\infty}^{\infty}e^{at}u(t)e^{-iwt} dt$ does not exist for $a > 0$, so the transform doesn't exist as stated after that.
Please carefully examine your question and correct the errors.
– Andy Walls Nov 21 '24 at 04:01
