I am trying to solve Collection Coupons (Problem 14) in Fifty Challenging Problems in Probability book which is given below:
Coupons in cereal boxes are numbered $1$ to $5$, and a set of one of each is required for a prize. With one coupon per box, how many boxes on the average are required to make a complete set?
I approached the given problem in the following way. Let's try to calculate the probability of getting all the coupons at the end of opening $n$th box. This means that previous $n-1$ boxes had one digit missing. Here for the last digit, we have $5$ choices and probability of getting the last digit as coupon in the $n$th box is $1/5$. We also need to make sure that apart from last box, no other box should have the last digit. Hence for each box other than last, probability of getting any digit other than last is $4/5$. Hence final probability of ending up with $n$ boxes to complete the set should be $$\left(\frac{4}{5}\right)^{n-1}\times\frac{1}{5}\times \binom 51.$$ Now we sum it from $n = 6$ to $\infty$ with additional term $5 \times \dfrac{5!}{5^5}$, where $\dfrac{5!}{5^5}$ is the probability of getting the all $5$ digits in the first $5$ boxes itself. After computing the series and adding the last term, I get the expected value of $16.576$. The correct expected value is $11.42$. Where am I going wrong?
