In first fundamental theorem of calculus,it states if $A(x)=\int_{a}^{x}f(t)dt$ then $A'(x)=f(x)$.But in second they say $\int_{a}^{b}f(t)dt=F(b)-F(a)$,But if we put $x=b$ in the first one we get $A(b)$.Then what is the difference between these two and how do we prove $A(b)=F(b)-F(a)$?
a_i_r
  • 739
    If $f$ is continuous, then the first theorem's consequent is true, which in turn guarantees that the second theorem's consequent is also true.$$$$ If on the other hand $f$ is not continuous, then the first theorem is inapplicable; if $f$ is integrable and has a primitive (despite not being continuous), then the second theorem's consequent is true.
    p.s. There exist functions that are integrable but have no primitive.
    – ryang Feb 14 '21 at 15:16
  • How do we prove $A(b)=F(b)-F(a)$ under valid assumptions – a_i_r Feb 14 '21 at 15:23
They have different assumptions.
In the first part you mentioned, $f$ is assumed to be continuous. In the second part, $f$ can be assumed only Riemann integrable on the closed interval $[a,b]$. When $f$ is continuous, the second part indeed follows from the first part.
See also a comparison of the statements in this article.
  • I didn't understand,please explain to me if A(b)=F(b)-F(a) – a_i_r Feb 14 '21 at 15:11
  • @AritraBarua Which part of the answer you don't understand? Please explain. –  Feb 14 '21 at 16:17
  • @AritraBarua: if you use $A(b)=F(b)-F(a)$, then you are using the first part, where $f$ is assumed to be continuous. –  Feb 14 '21 at 16:28
