I am looking for a calculus solution of the following problem:
Problem. (Berkeley Qual Spring 1990):
Let $n$ br a positive integer, and let $A_n:= (a_{ij}) \in M_n(\mathbb{R})$ be a matrix given by $a_{ii} =2,\ a_{i,i+1} = -1,\ a_{ij} = 0$ otherwise. For instance,
$A_4 = \begin{pmatrix} 2 & -1 & 0 & 0\\ -1 & 2 & -1 &0 \\ 0 & -1 & 2 & -1\\ 0 & 0 & -1 & 2 \end{pmatrix} $
Prove that every eigenvalue of $A$ is a positive real number.
Here is the solution I am trying to complete.
We proceed by induction on $n$. Let $p_n(t) := \det(A_n-t Id)$, i.e. the characteristic polynomial of $A_n$. This satisfies the recursive rule $p_{n+2}(t) =(2-t)p_{n+1}(t) - p_n(t)$. It suffices to show that $p_n>0$ for all $t<0$.
The base case is easy. For the induction step, it is sufficient to prove the bound $|p_n(t)| \le (2-t)p_{n+1}(t)$ for $t<0$. How do can we prove this bound?
It's clear from $\deg p_n(t) = n$ that for $t \to - \infty$, the bound is satisfied, but this is not enough.
Note: my question is not a solution to the Problem above (see Note 2), but rather a solution using my particular approach (or a similar approach doing calculus on characteristic polynomials).
Note 2: I already know two solutions; one is to prove $A_n$ is positive definite, and another is to prove some bounds for entries of eigenvectors. See Problem 7.5.27 in Berkeley Problems in Mathematics. The point of my question is to solve the Problem in as many was as possible.
user676464327
  • 428
  • 14
    There are many ways to prove that $A_n$ is positive definite. Here are four of them. (1) $A$ is positive definite because $A=(I-N)(I-N)^T+E_{nn}$, where $N$ is the upper triangular nilpotent Jordan block of size $n$. (2) Let $d_n=\det(A_n)$. Then $d_n=2d_{n-1}-d_{n-2}$. Hence $d_n-d_{n-1}=d_{n-1}-d_{n-2}=\cdots=d_2-d_1=3-2=1$ and $d_n=n+1>0$. Now apply Sylvester's criterion. (3) Using $A_n=e_1e_1^T+\sum_{i=1}^{n-1}(e_i-e_{i+1})(e_i-e_{i+1}^T)+e_ne_n^T$, prove that $x^TAx=0$ only if $x=0$... – user1551 Aug 29 '20 at 01:15
    ... (4) Determine the eigenvalues of $A_n$ directly. See e.g. the many answers to the question How to find the eigenvalues of tridiagonal Toeplitz matrix? All these four approaches are probably easier than yours. – user1551 Aug 29 '20 at 01:15
    easiest approach: Apply Gerschgoin Discs: it is immediate that all eigenvalues are real non-negative and Tausky's refinement tells you the matrix is non-singular thus it is PD. Another one: consider $\big(-\frac{1}{2}A +I\big)$ -- this is a transition matrix for a connected transient markov chain and thus all eigenvalues have modulus $\lt 1$ (or use Perron Frobenius theory) -- now negate and add $I$ to see that $\frac{1}{2}A$ has all eigenvalues with positive real part -- and since symmetric they are entirely real positive eigenvalues. – user8675309 Aug 29 '20 at 05:19
  • "It suffices to show that $p_n>0$ for all $t<0$." Impossible. Suppose $n$ is odd. Then $p_n$ is a real monic polynomial with of odd degree $n$. Hence $p_n\big(-\vert t\vert\big) \lt 0$ for $\vert t\vert$ large enough. – user8675309 Aug 29 '20 at 06:58
  • @user8675309 I just made a correction. With the definition of characteristic polynomial as $p_n(t) := \det(A_n - t Id)$, then we get leading order term $-t^n$ when $n$ odd, and so, $p_n(- |t|)\to \infty$ for $|t|$ large. – user676464327 Aug 29 '20 at 07:11
$$\left( \begin{array}{rr} 1 & 0 \\ - \frac{ 1 }{ 2 } & 1 \\ \end{array} \right) \left( \begin{array}{rr} 2 & 0 \\ 0 & \frac{ 3 }{ 2 } \\ \end{array} \right) \left( \begin{array}{rr} 1 & - \frac{ 1 }{ 2 } \\ 0 & 1 \\ \end{array} \right) = \left( \begin{array}{rr} 2 & - 1 \\ - 1 & 2 \\ \end{array} \right) $$
$$\left( \begin{array}{rrr} 1 & 0 & 0 \\ - \frac{ 1 }{ 2 } & 1 & 0 \\ 0 & - \frac{ 2 }{ 3 } & 1 \\ \end{array} \right) \left( \begin{array}{rrr} 2 & 0 & 0 \\ 0 & \frac{ 3 }{ 2 } & 0 \\ 0 & 0 & \frac{ 4 }{ 3 } \\ \end{array} \right) \left( \begin{array}{rrr} 1 & - \frac{ 1 }{ 2 } & 0 \\ 0 & 1 & - \frac{ 2 }{ 3 } \\ 0 & 0 & 1 \\ \end{array} \right) = \left( \begin{array}{rrr} 2 & - 1 & 0 \\ - 1 & 2 & - 1 \\ 0 & - 1 & 2 \\ \end{array} \right) $$
$$\left( \begin{array}{rrrr} 1 & 0 & 0 & 0 \\ - \frac{ 1 }{ 2 } & 1 & 0 & 0 \\ 0 & - \frac{ 2 }{ 3 } & 1 & 0 \\ 0 & 0 & - \frac{ 3 }{ 4 } & 1 \\ \end{array} \right) \left( \begin{array}{rrrr} 2 & 0 & 0 & 0 \\ 0 & \frac{ 3 }{ 2 } & 0 & 0 \\ 0 & 0 & \frac{ 4 }{ 3 } & 0 \\ 0 & 0 & 0 & \frac{ 5 }{ 4 } \\ \end{array} \right) \left( \begin{array}{rrrr} 1 & - \frac{ 1 }{ 2 } & 0 & 0 \\ 0 & 1 & - \frac{ 2 }{ 3 } & 0 \\ 0 & 0 & 1 & - \frac{ 3 }{ 4 } \\ 0 & 0 & 0 & 1 \\ \end{array} \right) = \left( \begin{array}{rrrr} 2 & - 1 & 0 & 0 \\ - 1 & 2 & - 1 & 0 \\ 0 & - 1 & 2 & - 1 \\ 0 & 0 & - 1 & 2 \\ \end{array} \right) $$ $$\left( \begin{array}{rrrrr} 1 & 0 & 0 & 0 & 0 \\ - \frac{ 1 }{ 2 } & 1 & 0 & 0 & 0 \\ 0 & - \frac{ 2 }{ 3 } & 1 & 0 & 0 \\ 0 & 0 & - \frac{ 3 }{ 4 } & 1 & 0 \\ 0 & 0 & 0 & - \frac{ 4 }{ 5 } & 1 \\ \end{array} \right) \left( \begin{array}{rrrrr} 2 & 0 & 0 & 0 & 0 \\ 0 & \frac{ 3 }{ 2 } & 0 & 0 & 0 \\ 0 & 0 & \frac{ 4 }{ 3 } & 0 & 0 \\ 0 & 0 & 0 & \frac{ 5 }{ 4 } & 0 \\ 0 & 0 & 0 & 0 & \frac{ 6 }{ 5 } \\ \end{array} \right) \left( \begin{array}{rrrrr} 1 & - \frac{ 1 }{ 2 } & 0 & 0 & 0 \\ 0 & 1 & - \frac{ 2 }{ 3 } & 0 & 0 \\ 0 & 0 & 1 & - \frac{ 3 }{ 4 } & 0 \\ 0 & 0 & 0 & 1 & - \frac{ 4 }{ 5 } \\ 0 & 0 & 0 & 0 & 1 \\ \end{array} \right) = \left( \begin{array}{rrrrr} 2 & - 1 & 0 & 0 & 0 \\ - 1 & 2 & - 1 & 0 & 0 \\ 0 & - 1 & 2 & - 1 & 0 \\ 0 & 0 & - 1 & 2 & - 1 \\ 0 & 0 & 0 & - 1 & 2 \\ \end{array} \right) $$
https://en.wikipedia.org/wiki/Sylvester%27s_law_of_inertia#Statement_in_terms_of_eigenvalues
Will Jagy
  • 146,052
    From the question: "Note: my question is not a solution to the Problem above (see Note 2), but rather a solution using my particular approach (or a similar approach doing calculus on characteristic polynomials)." – John Hughes Aug 29 '20 at 01:05
    @JohnHughes I know. Indeed, just yesterday I got about four downvotes on a picture of an ellipse that I did by hand; eventually I deleted it. I still think there is room for answering the question the OP should have asked. – Will Jagy Aug 29 '20 at 02:18
    Fair enough. I also suspected that OP might need to "strengthen the induction" to make it work, and that turns out to be true (see @user8675309's comment), so OP was asking for something impossible anyhow. – John Hughes Aug 29 '20 at 11:39
  • @JohnHughes thank you. – Will Jagy Aug 29 '20 at 14:03
We will find a formula for the eigenvalues of $n \times n$ matrix
$A = \begin{pmatrix}2 & -1 & 0 & \cdots & 0 \\-1 & 2 & -1 & \ddots & \vdots\\ 0 & -1 & \ddots & \ddots & 0\\ \vdots & \cdots & \ddots & 2 & -1 \\ 0 & \cdots & 0 & -1 & 2 \end{pmatrix}$
Solution:
Let $x = \begin{pmatrix}x_{1} \\ x_{2} \\ \vdots \\ x_{n-1} \\ x_{n} \end{pmatrix} $
The components in $(A - \lambda I)x = 0$ are $-x_{k-1} + (2-\lambda)x_{k} - x_{k+1} =0, k = 1, 2, \cdots, n$ with $x_{0} = x_{n+1} = 0$.
Treating that recurrence relation like a differential equation, we seek a solution of the form $x_{k} = cr^{k}$ and on plugging in we get:
$r^{2} - \gamma r + 1 = 0$, where $\gamma = 2 - \lambda$.
Note that we must have two distinct solutions for this quadratic equation since otherwise we will get the solutions $x_{k} = \alpha \rho^{k} + \beta k \rho^{k}$ which becomes zero for all $k$ since $x_{0} = 0$ and $x_{n + 1} = 0$ and since we are seeking an eigenvector this would not be allowed. Hence, we must have two distinct roots $r_{1}, r_{2}$ and the solutions are given by $x_{k} = \alpha r_{1}^{k} + \beta r_{2}^{k}$. Note that $x_{0} = 0 \implies \alpha = -\beta$ and this together with $x_{n + 1} = 0 \implies r_{2}^{n+1} - r_{1}^{n + 1} = 0 \implies$ that $\frac{r_{1}}{r_{2}}$ is a root of unity. Hence $r_{1} = r_{2} e^{2\frac{i \pi j} {n + 1}}$
Factoring and comparing the coefficients:
$r^{2} - \gamma r + 1 = (r - r_{1}) (r- r_{2}) = r^{2} - (r_{1} + r_{2}) r + r_{1}r_{2} \implies r_{1}r_{2} = 1, r_{1} + r_{2} = \gamma$.
We have $r_{1} = e^{\frac{i \pi j} {n + 1}}$, $r_{2} = e^{-\frac{i \pi j} {n + 1}}$
Hence, the eigenvalues of $A$ are $\lambda_{j} = 2- \gamma_{j} = 2- 2\cos \frac{j \pi}{n + 1} $ for $j = 1, 2, \cdots, n$
It follows that $\lambda_{j} > 0$.
I'm not sure I follow why working with a recurrence and applying triangle inequality is 'calculus'. The below is a proof that comes down to (1.) using the recurrence and (2.) applying Cauchy Interlacing.
The recurrence
where $p_n(t) := (-1)^n\cdot \det\big(tI_n - A_n\big)= \det\big(A_n-tI_n \big)$
i.e. it is $(-1)^n$ times the characteristic polynomial.
By induction hypothesis we have $A_n$ having all positive eigenvalues, that is
$p_n(t)= \big(\lambda_1^{(n)}-t\big)\big(\lambda_2^{(n)}-t\big)...\big(\lambda_n^{(n)}-t\big)$
with each $\lambda_k^{(n)}\gt 0$
We want to prove this implies $\lambda_k^{(n+1)}\gt 0$ for $k\in \{1,2,...,n,n+1\}$
Now suppose $p_{n+1}(t^*) =0$ for some $t^*\in(-\infty, 0]$ and apply the recurrence twice.
$p_{n+2}(t^*) =(2-t^*)p_{n+1}(t^*) - p_n(t^*) = 0 - p_n(t^*) \lt 0$
$p_{n+3}(t^*) =(2-t^*)p_{n+2}(t^*) - p_{n+1}(t^*) = (2-t^*)p_{n+2}(t^*)-0 \lt 0$
The eigenvalues in each of these polynomials interlace
$0=p_{n+1}(t^*)= \Big(\big(\lambda_1^{(n+1)}-t^*\big)...\big(\lambda_n^{(n+1)}-t^*\big)\Big)\cdot \big(\lambda_{n+1}^{(n+1)}-t^*\big)$
Interlacing of eigenvalues of $A_{n}$ and $A_{n+1}$ tells us the first $n$ terms in the above are necessarily positive and the last term is zero.
$p_{n+3}(t^*)= \Big(\big(\lambda_1^{(n+3)}-t^*\big)...\big(\lambda_n^{(n+3)}-t^*\big)\big(\lambda_{n+1}^{(n+3)}-t^*\big)\Big)\cdot\Big(\big(\lambda_{n+2}^{(n+3)}-t^*\big)\big(\lambda_{n+3}^{(n+3)}-t^*\big)\Big)$
Since $t^*$ is not a root for $p_{n+3}$ but the eigenvalues of $A_{n+3}$ interlace with those of $A_{n+1}$ we see the first $n+1$ terms are all positive and the last 2 terms are negative giving us
$0\gt p_{n+3}(t^*)= \Big(\gt 0 \Big)\cdot \Big(\gt 0\Big)\gt 0$
which is a contradiction.
Thus $p_{n+1}(t^*) \neq 0$ for any $t^*\in(-\infty, 0]$ and the positivity of all eigenvalues follows.
addendum
to see the interlacing of e.g. eigenvalues of e.g. the $n$ and $n+1$ dim case, consider with standard basis vectors $\mathbf e_k\in \mathbb R^{n+1}$
$B := \bigg[\begin{array}{c|c|c|c|c} \mathbf e_1 & \mathbf e_2 &\cdots &\mathbf e_n \end{array}\bigg]$
$B^TB = I_n$ and
$B^T\big(A_{n+1}\big)B = A_n$
user8675309
  • 12,193
