I have a nonlinear system of equations as $$ \left(\mathbf{K}_{\mathbf{L}}+\mathbf{K}_{\mathbf{N L}}(\mathbf{X})\right) \mathbf{X}=\mathbf{F} $$ in which $\mathbf{K}_{\mathbf{N L}}(\mathbf{X})$ represents the nonlinear stiffness matrix which is dependent to $\mathbf{X}$. I'm solving with Picard iteration like this:
- first ignore the nonlinear stiffness matrix and solve the linear matrix for $\mathbf{X}$.
- put the resulting $\mathbf{X}$ in the nonlinear stiffness matrix and solve the full equation for $\mathbf{X}$.
- check convergence and repeat 2 if the convergence is not satisfied.
the problem i have here is when the force vector($\mathbf{F}$) is small the nonlinear equation solves very fast but when i increase the force beyond some threshold it gets ages to converge. i have tried to solve it using Matlab fsolve function with algorithms like 'trust-region' and 'levenberg-marquardt' but the same thing happens with large force vectors.
is there any way i can improve the convergence speed ?
p.s. heres a gif of the result vector $\mathbf{X}$ inside the convergence loop with a force vector slighly over the threshold.
edit(more details): so my problem is bending of a nonlinear timoshenko beam that has three governing equations as below: $$ -\frac{d}{d x}\left\{A_{x x}\left[\frac{d u}{d x}+\frac{1}{2}\left(\frac{d w}{d x}\right)^{2}\right]+B_{x x} \frac{d \phi_{x}}{d x}\right\}=0 $$ $$ -\frac{d}{d x}\left\{A_{x x} \frac{d w}{d x}\left[\frac{d u}{d x}+\frac{1}{2}\left(\frac{d w}{d x}\right)^{2}\right]+B_{x x} \frac{d w}{d x} \frac{d \phi_{x}}{d x}\right\}-\frac{d}{d x}\left[S_{x x}\left(\frac{d w}{d x}+\phi_{x}\right)\right]=q $$ $$ -\frac{d}{d x}\left\{D_{x x} \frac{d \phi_{x}}{d x}+B_{x x}\left[\frac{d u}{d x}+\frac{1}{2}\left(\frac{d w}{d x}\right)^{2}\right]\right\}+S_{x x}\left(\frac{d w}{d x}+\phi_{x}\right)=0 $$ along with the proper boundary conditions and using finite difference, when assembled they form: $$ \left(\mathbf{K}_{\mathbf{L}}+\mathbf{K}_{\mathbf{N L}}(\mathbf{X})\right) \mathbf{X}=\mathbf{F} $$
ode23sand others? – user10354138 Jul 26 '20 at 09:56fsolveandode23s? – omgtheykilledkenny Jul 26 '20 at 10:23Xitself? because X is has three separate variables{u;w;s}– omgtheykilledkenny Jul 29 '20 at 12:19fsolveand from the documentations it uses Newtons methos,but the same happens. – omgtheykilledkenny Jul 30 '20 at 09:54torch.optim.LBFGSoptimizer. – Hyperplane Aug 04 '20 at 10:58
