25
While going through the list of problems posed by Ramanujan in Journal of Indian Mathematical Society I came across this problem involving theta functions:
Prove that $$\frac{1}{2}+\sum_{n=1}^{\infty} e^{-\pi n^2x}\cos(\pi n^2\sqrt{1-x^2})=\frac{\sqrt{2}+\sqrt{1+x}}{\sqrt{1-x}}\sum_{n=1}^{\infty}e^{-\pi n^2x}\sin(\pi n^2\sqrt{1-x^2})$$ and deduce the following:
  • ${\displaystyle \frac{1}{2}+\sum_{n=1}^{\infty} e^{-\pi n^2}=\sqrt{5\sqrt{5}-10}\left(\frac{1}{2}+\sum_{n=1}^{\infty} e^{-5\pi n^2}\right)} $
  • ${\displaystyle \sum_{n=1}^{\infty} e^{-\pi n^2}\left(\pi n^2-\frac{1}{4}\right)=\frac{1}{8}} $
The sums in above problem are clearly based on theta functions and we use a simplified notation here to define them. If $\tau$ is any complex number with positive imaginary part then we define $$\vartheta(\tau) =\sum_{n\in\mathbb {Z}} e^{\pi i\tau n^2}$$ and one of the key properties of theta function defined above is $$\vartheta(\tau) =(-i\tau) ^{-1/2}\vartheta(-1/\tau)$$ Ramanujan's first formula probably assumes that $x\in(0,1)$ and hence one can write $x=\cos t$ with $t\in(0,\pi/2)$ and we can consider the complex number $\tau=\sin t +i\cos t$ which clearly has positive imaginary part. The choice of $\tau$ in this manner is done because it gives us $$(-i\tau) ^{-1/2}=\cos(t/2) +i\sin(t/2)=\sqrt{\frac{1+x}{2}}+i\sqrt{\frac{1-x}{2}}$$ and $$-1/\tau=-\sin t+i\cos t=-\sqrt{1-x^2}+ix$$ Using this value of $\tau$ in the transformation formula for theta functions we get $$1+2A+2iB=\frac{\sqrt{1+x}+i\sqrt{1-x}}{\sqrt{2}}(1+2A-2iB)$$ where $$A=\sum_{n=1}^{\infty}e^{-\pi n^2x}\cos(\pi n^2\sqrt{1-x^2}),B=\sum_{n=1}^{\infty} e^{-\pi n^2x}\sin(\pi n^2\sqrt{1-x^2})$$ and equating real parts we get $$1+2A=(1+2A)\sqrt {\frac{1+x}{2}}+2B\sqrt{\frac{1-x}{2}}$$ or $$\frac{1}{2}+A=\frac{\sqrt{2}+\sqrt{1+x}}{\sqrt{1-x}}B$$ In this manner the key formula of Ramanujan is established.
Out of the next two corollaries I was able to prove the second one easily by dividing the main formula by $\sqrt{1-x^2}$ and then taking limits as $x\to 1^{-}$. The first one dealing with $\sum e^{-5\pi n^2}$ was really looking difficult to obtain.
My question is
How to obtain the first corollary dealing with $\sum e^{-5\pi n^2}$ from the main formula of Ramanujan?
Since the formula appears to be using $x\in(0,1)$ I don't see a way to put $x=5$. Even if one does that both sides will contain the sums involving $\sum e^{-5\pi n^2}$ and it appears rather mysterious to obtain a link between $\sum e^{-\pi n^2}$ and $\sum e^{-5\pi n^2}$.
The link between these two sums can be obtained using a modular equation of degree 5, but the calculations involved are tedious (for this technique in action see this answer which evaluates $\sum_{n\in\mathbb {Z}} e^{-3\pi n^2}$). I was therefore hoping for some easier approach as indicated by Ramanujan. Maybe I am mising something obvious here.
    Up to the question, this is impressive (as usual). Cheers and (+1). – Claude Leibovici Jun 05 '20 at 02:50
  • $$\sum_{n\in \mathbb{Z}} e^{-5\pi n^2}$$ can be done is a more condensed way, without using modular equation. One can even calculate $$\sum_{n\in \mathbb{Z}} e^{-N\pi n^2}$$ for $N\leq 100$ in a reasonable amount of time. – pisco Jun 05 '20 at 03:16
  • @reuns : there is some issue with your equations. If $x=\sqrt{5},i\sqrt {1-x^2}=2$ how come they add up upto $5$. Note that $$(x+i\sqrt {1-x^2})(x-i\sqrt{1-x^2})=1$$ so if own factor is $5$ the other has to be $1/5$. – Paramanand Singh Jun 05 '20 at 03:20
  • @pisco: Is it really possible by hand, pen, paper? I don't have access to any math software and I don't even know how to use them. Anyway if you can post your ideas as an alternative approach do give an answer. – Paramanand Singh Jun 05 '20 at 03:22
  • @AlapanDas: I have mentioned about that. Divide by $\sqrt{1-x^2}$ and take limits as $x\to 1^-$. – Paramanand Singh Jun 05 '20 at 03:24
  • @reuns: I will get some expression involving $\sum e^{-\pi n^2\sqrt {5}}$. – Paramanand Singh Jun 05 '20 at 03:34
  • @ParamanandSingh At least for $\sum_{n\in \mathbb{Z}} e^{-N\pi n^2}$ with $N\leq 10$, it is possible by hand, pen and paper, if you are willing to numerically calculate $j$-invariant to some precision, say $8$ decimal digits (which can be done via a rapid convergent serie). – pisco Jun 05 '20 at 03:53
  • @pisco: please post that as an answer giving some details (not necessarily including calculations) whenever time permits. At least I can try for $N=5$ based on that. – Paramanand Singh Jun 05 '20 at 03:55
Finally I have managed to prove the identity in question. It appears that the main formula (proved in question) as well as its first corollary are both derived from the transformation formula for theta functions rather than being derived from each other. This means that the issue at hand is not really the corollary of the main result as I was expecting.
Let us write $$a=\vartheta(i), b=\vartheta(5i),c=\vartheta(i/5)\tag{1}$$ and we have to prove that $$a=b\sqrt {5\sqrt{5}-10}\tag{2}$$ This is done in two steps and the first one out of these two is obvious. Putting $\tau=5i$ in the transformation formula for theta functions (see the question) we get $$c=b\sqrt{5}\tag{3}$$ In order to prove $(2)$ we need another relation between $a, b$ and $c$ and use it together with $(3)$.
This is the second step where we put $\tau=i+2$ so that $$(-i\tau) ^{-1/2}=\frac{\sqrt{1+2i}}{\sqrt{5}}=\sqrt{\frac{\sqrt{5}+1}{10}}+i\sqrt{\frac{\sqrt{5}-1}{10}}=p+iq\text{ (say)} \tag{4}$$ and $$-\frac{1}{\tau}=\frac{i-2}{5}$$ Using these values in the transformation formula for theta function (and also noting that $\vartheta(\tau +2)=\vartheta(\tau)$) we get $$a=(p+iq)\left\{1+2\sum_{n=1}^{\infty} e^{-\pi n^2/5}\left(\cos\frac{2\pi n^2}{5}-i\sin\frac{2\pi n^2}{5}\right)\right\}$$ Note that the left hand side is purely real and hence equating real parts we get $$a=p\left(1 +2\sum_{n=1}^{\infty} e^{-\pi n^2/5}\cos\frac{2\pi n^2}{5}\right)+2q\sum_{n=1}^{\infty}e^{-\pi n^2/5}\sin\frac{2\pi n^2}{5}$$ and equating imaginary parts we get $$ 2p\sum_{n=1}^{\infty} e^{-\pi n^2/5}\sin\frac{2\pi n^2}{5}=q\left(1+2\sum_{n=1}^{\infty} e^{-\pi n^2/5}\cos\frac{2\pi n^2}{5}\right)$$ Combining these equations we have $$a=\frac{p^2+q^2}{p}\left(1+2\sum_{n=1}^{\infty}e^{-\pi n^2/5}\cos\frac{2\pi n^2}{5}\right)$$ And now we have the magic happening here. If $5\mid n$ then the cosine term equals $1$ otherwise it equals $\cos(2\pi/5)$. We can thus rewrite the above equation as $$a=\frac{p^2+q^2}{p}\left(1+2\cos\frac{2\pi}{5}\sum_{n>0,5\nmid n} e^{-\pi n^2/5}+2\sum_{n=1}^{\infty} e^{-5\pi n^2}\right)$$ and this can be further rewritten as $$a=\frac{p^2+q^2}{p}\left\{1+2\cos\frac{2\pi}{5}\sum_{n=1}^{\infty} e^{-\pi n^2/5}+2\left(1-\cos\frac{2\pi}{5}\right)\sum_{n=1}^{\infty}e^{-5\pi n^2}\right\}$$ Finally this means that \begin{align} a&=\frac{p^2+q^2}{p}\left(1+(c-1)\cos\frac{2\pi}{5}+2(b-1)\sin^2\frac{\pi}{5}\right)\notag\\ &=b\cdot\frac{p^2+q^2}{p}\left(\sqrt{5}\cos\frac{2\pi}{5}+1-\cos\frac{2\pi}{5}\right)\text{ (using (3))}\notag\\ &=\frac{b} {p\sqrt{5}}\left(1+\frac{(\sqrt{5}-1)^2}{4}\right)\text{ (using (4))}\notag\\ &=\frac{b}{p}\cdot\frac{\sqrt{5}-1}{2}\notag\\ &=b\sqrt{\frac{5(\sqrt{5}-1)(3-\sqrt{5})}{4}}\notag\\ &=b\sqrt{5(\sqrt{5}-2)}\notag \end{align} I think this is almost what Ramanujan had in his mind when he posed the problem.
  • +1 I suspect that this method was used by Ramanujan to obtain modular equations of high degree or at least as a tool for this purpose. This shows the link between $K(k_{1})$ and $K(k_{25})$. What do you think? Have you tried to do the same for other cases? – User-Refolio Mar 30 '25 at 08:49
  • @User: it is the other way round. Modular equations between $k, l$ can be used to obtain the ratio $K/L$. Ramanujan unfortunately never told us how he derived his modular equations or even any steps of calculation he did with a given modular equation. The reason for this is probably that these involved laborious symbol manipulation and required lot of paper (a costly resource for Ramanujan at that time) to write them down. He probably did those calculations on a slate and wiped them off when final result was arrived at. – Paramanand Singh Mar 30 '25 at 11:20
  • @User: Ramanujan's work on modular equations was done before he became famous with Hardy and I think he never tried to mention the steps for modular equations during his time in England. He was busy producing stuff on partition theory at that time. – Paramanand Singh Mar 30 '25 at 11:23
  • It should also be mentioned that in some cases Ramanujan wrote his modular equations in terms of algebraic expressions for multiplier $K/L$ rather than writing a relation between $k, l$. This was probably because in such cases the formula for $K/L$ appeared simpler visibly compared to the modular equation between $k, l$ @User – Paramanand Singh Mar 30 '25 at 11:26
  • Let me mention why I suspect that. Ramanujan gave hints and one is when he says, $K'(k)/K(k)=\sqrt{r}$ when r is a perfect square those values have an algebraic relation with $K'(k)/K(k)=1$ i.e: "can be found in finite terms, when n = 2, 3, 4, 5, . . . , from the equations in Table III. We can use the same table to find the sum of (19) when n = 9, 25, 49, . . . ; but then we have also to use the equation: $\frac{3}{\pi}=1-24(...)$" – User-Refolio Mar 30 '25 at 11:47
  • @User: the hint works fine. You should check that the formulas of $f(n) $ for odd $n$ (table III) in his paper are symmetric in $k, l$ as well as symmetric in $kl, k'l'$. Putting $k=k'=2^{-1/2}$ these expressions are symmetric in $l, l'$. This helps a lot as shown in https://math.stackexchange.com/a/2285072/72031 for $n=5$. – Paramanand Singh Mar 30 '25 at 13:48
