I am confused on how to go forward with solving this question. It is:
If a number x is divided by 5, it leaves a remainder of 3. If x is divided by 7, it leaves a remainder of 2. If x is divided by 3, it leaves a remainder of 1. What is x?
My method is that I check the units digits of each multiple, so in this case, the units digit of the number can only be equal to 8. It's because a multiple of 5 plus 3 either ends in 8 or 3, but a multiple of 3 plus 1 cannot end in 3. I then brute force using other values that the question give.
I have already solved it to 58 (I think it is right), but I am looking for a quicker method than my previous one.
Hint $\,\bmod 3,5,7\!:\ 2x\equiv 11\iff \bmod 105\!:\ 2x\equiv 11\equiv 116\iff \bbox[5px,border:1px solid #c00]{x\equiv 58}\ \ $
Remark $ $ This method works for residues and moduli in arithmetic progression, as here, i.e.
$$\begin{align} &x\equiv 2\!\!\pmod{7}\\ &x\equiv 3\!\!\pmod{5}\\ &x\equiv 4\!\!\pmod{3}\end{align}\qquad\qquad\qquad\qquad$$
Note progressions $\, 7,5,3 = 7\!-\!2k\ $ and $\ 2,3,4 = 2\!+\!k,\,$ i.e. $\,x\equiv 2\!+\!k\pmod{7\!-\!2k}\,$ so
$\!\!\bmod\, \color{#c00}{7\!-\!2k}\!:\,\ x\equiv 2\!+\!k\iff 2x\equiv 4\!+\!\color{#c00}{2k}\equiv 4\!+\!\color{#c00}7\equiv 11\,$ hence
$7,5,3\mid 2x\!-\!11\iff 105\mid 2x\!-\!11$ $\iff 105\mid 2x\!-\!11\!-\!105=2(x\!-\!58)\iff 105\mid x\!-\!58$
For further discussion of this method see this answer and its linked questions (coincidentally that boils down to the modular fraction $\,x\equiv -11/2,\,$ i.e. the negative of above).
Typically human-devised CRT exercises involve small numbers - which increases the probability that such linear progression structure will be evident.
Bill Dubuque
  • 282,220
  • This actually makes sense, but I still have a few questions. After reading both this answer and your previous answer, I don't get how you make the 2k into 7. Also, I do not get why you add 753. Is it because 753 is the lcm, and if so, why does that work? – aSquaredRush Apr 19 '20 at 20:36
    @Aarush We worked modulo $,m :=\color{#c00}{ 7-2k},$ so $,0\equiv m=7-2k\iff \color{#c00}{2k\equiv 7}.,$ The answer is $,x\equiv 11/2\pmod{!105}$ so we add the modulus $105(\equiv 0)$ to numerator to make it even so divisible by $2,,$ i.e. to get an exact quotient. This is a standard trick to divide by $2$ for odd moduli, e.g. see here, Without fractions $, \color{#c00}2x\equiv 11\equiv 11!+!105\equiv \color{#c00}2\cdot 58\iff x\equiv 58,$ by cancelling $\color{#c00}2$ (valid since $2$ is coprime to $105$ so invertible). – Bill Dubuque Apr 19 '20 at 22:03
  • This makes perfect sense. Something I struggled on was that 0 ≡ , but it makes sense now. – aSquaredRush Apr 20 '20 at 00:40
Here is a solution using Bezout coeffecients and isomorphisms as in the Chinese remainder theorem:
$x\cong3\pmod5$ and $x\cong2\pmod7$. Since $-4\cdot5+3\cdot7=1$, we get $x\cong-20\cdot2+21\cdot3\cong23\pmod{35}$.
Then $x\cong1\pmod3$ and $x\cong23\pmod{35}$. We solve with Bezout coefficients again. $3\cdot12-1\cdot 35=1$. So $x\cong36\cdot23-35\cdot1\cong793\cong58\pmod{105}$.
Granted @Bill, er, @Gone's solution is better.
