Two values, $x$ and $y$ are selected at random and independently of each other from the interval. What is the probability.
The only idea I have thought of is using BinomPdf, but I still don't know how to implement that into this.
This is a question I am solving on my own that I have discovered. If you send the answer and work it would not assist me cheating or anything malicious.
N. Virgo
  • 7,904
View the two numbers as coordinates of a point in the unit square. The points of interest are above the line $y=x+\frac 12$ or below the line $y=x-\frac 12$. That is two triangles. Compute their total area and you have the probability as the area of the square is $1$.
Ross Millikan
  • 383,099
As with many questions in mathematics, the best way to start is by making a picture!
Consider the following image, which I stole from an example given by Peter Woolfitt in this answer to an unreleated question.
Soltuion
As noted in the original source:
The [picture above] is the set of points $(x,y)$ such that $|x−y|\leq\dfrac{1}{2}$
The answer you are looking for is precisely the proportion of area that is white. Can you figure out what this is?
