Wikipedia states:
In mathematics, a formal power series is a generalization of a polynomial, where the number of terms is allowed to be infinite; this implies giving up the possibility of replacing the variable in the polynomial with an arbitrary number. Thus a formal power series differs from a polynomial in that it may have infinitely many terms, and differs from a power series, whose variables can take on numerical values.
What I am getting from this is that in both polynomials and formal power series, the variables "don't represent numbers". But I'm not exactly sure what this means, or what they do represent. Also it seems to be inconsistent with how I've been using polynomials, which is very much as "variables representing numbers".
So basically I'm conceptually confused about what this means, and can't really understand how they're being used.
user56834
  • 12,323
    In a formal power series we only care about the "form" of the series (i.e. the coefficients), and not about whether the series converges. – 79037662 Oct 15 '19 at 17:04
  • As for what they are used for, the textbook "generatingfunctionology" by Herbert S.Wilf gives a good introduction on how formal power series are used in, say, combinatorics. – 79037662 Oct 15 '19 at 17:06
  • Not a duplicate, but the essential answer is here: https://math.stackexchange.com/questions/2185587/what-actually-is-a-polynomial/2185648#2185648 – Ethan Bolker Oct 15 '19 at 17:09
  • There is a problem with both answers, and the treatment of polynomials in most (?) textbooks, including Godement's Algebra (1969), where I was first troubled by it. If one defines $X$ as the sequence of elements $(0, 1, 0, 0, \ldots)$ of a ring $K$, and if, as usual, one identifies $K$ with a subring of $K[X]$, then it is contradictory to define $K[X, Y] = (K[X])[Y]$ (as Godement does) because this implies $Y = X$. How, then, should one define multivariate polynomials? (The first and third editions of Lang's Algebra differ in their approaches, but neither seems to be open to my objection.) – Calum Gilhooley Oct 15 '19 at 18:08
  • @CalumGilhooley I don't think is implies $Y=X$. What makes you believe this? – Jean-Claude Arbaut Oct 15 '19 at 18:36
  • @Jean-ClaudeArbaut Whatever it means to "identify" one ring with a subring of another, once an identification has been made, it cannot be unmade. Then the $0,1$ of $K$ are literally the same as the $0,1$ of $K[X]$, therefore the $(0,1,0,0,\ldots)$ of $(K[X])[Y]$ is literally the same as the $(0,1,0,0,\ldots)$ of $K[X]$, i.e. $Y$ is literally the same as $X$. Perhaps I was bamboozled by the questionable advice on page 19 of Godement's book: "Also we recommend [the beginner] to take all definitions of technical terms absolutely literally." But how does one actually avoid the implication $Y=X$? – Calum Gilhooley Oct 15 '19 at 19:25
  • @CalumGilhooley You are doing it wrong. You identify $K$ as a subring of $K[X]$, means simply $(\alpha,0,0,0,\dots)$ is a subring of $K[X]$. When you are considering $(K[X])[Y]$, the coefficients are themselves formal series, or if you prefer "sequences of coefficients". And you identify $K[X]$ with a subring of $K[X,Y]$, as $(\alpha,0,0,0,\dots)$, where $\alpha$ is a formal series in $K[X]$. Nowhere there is $X=Y$. Actually, nowhere there is an $X$ or an $Y$, if you prefer to write the definitions without them. – Jean-Claude Arbaut Oct 15 '19 at 19:49
  • @Jean-ClaudeArbaut I'm prepared to accept that I'm misinterpreting the notion of identification in mathematics, especially as it has always seemed deeply confusing to me, in lots of ways. But if I am interpreting it wrongly, where is it explained how to interpret it rightly? Also, surely (to take a different and perhaps less confusing example), when $\mathbb{Q}$ is "identified" with a subfield of $\mathbb{R}$, no-one then goes around saying that elements of the former aren't literally elements of the latter. Indeed, wouldn't such a claim usually be taken as evidence of mathematical immaturity? – Calum Gilhooley Oct 15 '19 at 20:00
The best way to see this: forget about the $X$ in a polynomial or a formal power series, they are really sequences of coefficients, with no constraint on their values, with some specific rules of computation for addition and multiplication.
A power series, however, involves some limiting process, and that requires specific conditions, namely that the series converges.
For instance, you can manipulate $S=\sum_{n=0}^{\infty} x^n$ as a formal power series, and you won't consider convergence, only the operations on it, for instance $S^2=1+2x+3x^2+\dots$. That is, the coefficients of $S$ are $(1,1,1,\dots)$ while the coefficients of $S^2=(1,2,3,\dots)$. But you may also consider $T=\sum_{n=0}^{\infty} n! x^n$, it's a valid formal power series.
Now, for a power series, you require convergence. It's possible to prove that a power series in $x$ converges for all complex number $x$ such that $|x|<R$, for some real (of infinite) $R$. This $R$ is unique and is called the radius of convergence. For instance, the series $S$ above has radius $1$. It converges for $|x|<1$ to the number $\frac{1}{1-x}$. The series $T$ has radius $0$: it never converges if $x\ne0$. As a power series, it's almost useless, but as a formal power series, it can still be useful (we don't care that it does not converge).
There is a similar distinction between a polynom and a polynomial function. But here it's even more tricky, because in the usual undergraduate courses polynom are considered with coefficients in $\Bbb R$ or $\Bbb C$, and there many properties of polynomial directly relate to properties of the associated polynomial function.
When coefficients are in a finite field, it's more surprising. For instance, in $\Bbb F_2$, the finite field with two elements, the polynom $X^2+X$ is not the null polynomial (the null polynomial has null coefficients). However, the function $x\to x^2+x$ only takes the value $0$.
Jean-Claude Arbaut
  • 23,601
  • 53
  • 88
  • But what type of object is the formal power series? What does the word refer to? – user56834 Oct 15 '19 at 17:09
  • @user56834 It's an expression of the form $a_0+a_1X+a_2X^2+\cdots$, where there may be infinitely many terms. But these are not additions in the usual sense. Consider this as a symbolic representation. You could as well consider only the sequence of coefficients, as long as you apply the same rules. – Jean-Claude Arbaut Oct 15 '19 at 17:12
  • @Jean-ClaudeArbaut What does it mean to say that something is "an expression of the form"? – Gleison Stanlley Jun 05 '23 at 20:59
The Wikipedia definitions are not perfect. Let's go at this a little differently.
A formal polynomial is a finite ordered list of coefficients. We use powers of an indeterminant to mark where in the list each coefficient is. For instance (where I write out all the numbers that are normally elided) $1 x^2 + 2 x^1 + 3 x^0$ is a different polynomial from $3 x^2 + 2 x^1 + 1 x^0$ because, for instance, the coefficients in the $x^2$ place are different. Notee the similarity between this notion and positional notation for writing numbers.
A formal power series is a potentially infinite ordered list of coefficients. We use powers of an indeterminant to mark where in the list each coefficient is. Note that formal polynomials are formal power series (where, once the power of the marking is high enough, all the coefficients are zero).
Notice that for formal objects, the indeterminate is just a marking tool, it is not a "variable" or something that can be "evaluated". We can add these ideas. We can evaluate these objects by specializing the indeterminate to a value. When you do this, you get polynomials and power series.
For power series, a new idea comes into play: convergence. Some lists of coefficients and certain specializations of the indeterminate may not produce an infinite sum that has a value. An easy example is specializing the formal power series with all coefficients set to $1$ by setting the indeterminant also to $1$, so the power series is a sum of infinitely many copies of $1$, which does not converge. So, while a formal power series has no convergence issues (because you never pretend to evaluate a formal power series), a power series has issues of convergence.
Notice that because we are writing (finite or infinite) lists as formal power objects, we can add them (just like in positional notation), subtract, and multiply them, which operations should seem familiar. We can also interleave them, reverse them, concatenate them, sort them, and do other operations that are sensible for lists, which perhaps seems less familiar from the context of polynomials.
Eric Towers
  • 70,953
