16
I know how to solve a basic quadratic equation with the formula
$$t_{1,2}=\dfrac{-b\pm\sqrt{b^2-4ac}}{2a}$$
but I learned that if $b \approx \sqrt{b^2-4ac}$ floating point precision may give slightly wrong results and this approach is better. It works, indeed. But why? Is there a simple explanation on why this works?
5 Answers5
19
We are accustomed to solving the equation $ax^2+bx+c=0$ by using the Quadratic Formula $$x=\frac{-b\pm \sqrt{b^2-4ac}}{2a}.$$ Alternately, we can use the Citardauq Formula $$x=\frac{2c}{-b\mp \sqrt{b^2-4ac}}.$$ When $|4ac|$ is small in comparison with $|b|$, one of the roots as computed by the Quadratic Formula may suffer serious loss of precision, because in the numerator we are finding the difference of large nearly equal quantities. Precisely that root is then nicely computed with no loss of precision by the Citardauq Formula.
A simpler way of dealing with the problem is to note that the product of the roots of $ax^2+bx+c=0$ is $c/a$. So if we can compute one of the roots $r_1$ to high precision, the other root $r_2$ can be computed from $r_1r_2=c/a$ with no loss of precision.
pyrrhic
  • 479
André Nicolas
  • 514,336
As the other comments mention, there is loss of precision when subtracting similar values. So you want to compute one root $r_1$ of $a x^2 + b x + c = 0$ without substraction of possibly similar values and get the other from the relation $r_2 = \frac{c}{a r_1}$. If $4 a c$ is small with respect to $b^2$, $\sqrt{b^2 - 4 a c} \approx b$. So the general strategy is:
  • If $b < 0$, compute $r_1 = \frac{- b + \sqrt{b^2 - 4 a c}}{2 a}$
  • If $b > 0$, compute $r_1 = \frac{- b - \sqrt{b^2 - 4 a c}}{2 a}$
  • If $b = 0$, $r_1 = \sqrt{\frac{c}{a}}$, $r_2 = - \sqrt{\frac{c}{a}}$
lumbric
  • 308
vonbrand
  • 28,394
Any time you subtract two nearly equal numbers there is loss of precision. Imagine we work in scientific notation with five decimal digits available. The number $10100$ is represented as $1.0100 E5$ and you can think of it having a potential error of $\pm 0.5$ as anything from $10099.5$ to $10100.5$ would get the same representation. If we now subtract it from $10200=1.0200 E5$ we get $100=1.0000 E2$ but the error could be $\pm 1$ (in the worst case). We only have three digits of precision now, instead of 5, though it will be represented still with $5$ digits.
For the specific case of the quadratic formula, if $4ac \ll b^2,$ you have $-b+\sqrt{b^2-4ac}=-b+b\sqrt {1-\frac {4ac}{b^2}}\approx -b+b(1-\frac {2ac}{b^2})=-\frac {2ac}b$ and the much larger $b$ has canceled, losing precision.
Ross Millikan
  • 383,099
  • Thank you, any chance to proof that the two methods are equivalent except empirically by testing it with values? – John Smith Feb 22 '13 at 18:26
  • @JohnSmith: empirically testing will not prove them equivalent. The idea is that you compute one root by choosing the $\pm$ sign so the two terms are the same sign and add. Then you use the fact that if $r1, r2$ are the two roots of the quadratic, they multiply to $\frac ca$-the quadratic factors as $a(x-r1)(x-r2)=ax^2-a(r1+r2)x+ar1r2$ – Ross Millikan Feb 22 '13 at 18:30
If you have two roots $r_1$ and $r_2$, then the quadratic can be written in factored form $a(x-r_1)(x-r_2)=0$. Expanded we get $ax^2 - a(r_1+r_2)x + ar_1r_2=0$. This is basically Vieta's formulas consolidated into one equation. As you can see, given any quadratic $ax^2 + bx + c=0$, the coefficients are $b=-a(r_1+r_2)$ and $c=ar_1r_2$, or as Vieta put it, $-\frac{b}{a}= r_1+r_2$ and $\frac{c}{a}=r_1r_2$.
Ignore the first of the two and focus on the second. We can express one root in terms of the other as $\frac{c}{ar_1} = r_2$. This should not be unreasonable to you.
This is not an approximate relationship, its an exact relationship and should work all the time, not just when $b^2\gg 4ac$. This argument, though, is from a pure-mathematical perspective.
The "Citarduaq formula" AFAIK appears for the first time in literature in the papers by Forsythe (Stanford, late 60s), supposedly also a rework by Kahan same period. It appears clearly in the Goldberg paper "What every scientist should know about floating point arithmetic" in the 90s. Technically there is always loss of precision in the solution even if you choose the alternative formula for $b<0$, because there's cancellation in the discriminant at the denominator, but of course much less than in the original formula.
