Let me elaborate a little on the matter that I've been mulling over for a little while. This essentially concerns the summation of $1+2+3+...$, how it equals $-1/12$ (in a certain sense, obviously not normal circumstances), and how this seems to strangely coincide with the Riemann zeta function at $s=-1$.
I'm essentially concerned over whether this is a coincidence, or if there's something deeper at play here. It would certainly strike me as one heck of a coincidence.
I'll elaborate a bit for those unfamiliar with these matters...
The Value of $\zeta(-1)$:
We know, for $s \in \mathbb{C}$, with $Re(s)>1$, we can define the Riemann zeta function by
$$\zeta(s) = \sum_{n=1}^\infty \frac{1}{n^s}$$
This can be analytically continued to the entirety of the complex plane, giving a definition of the function for $Re(s)<1, s\neq1$:
$$\zeta(s) = 2^s \pi^{s-1} \sin\left(\frac{\pi s}{2} \right) \Gamma (1-s) \zeta(1-s)$$
Through this and the known result $\zeta(2)=\pi^2/6$ we can see that
$$\zeta(-1) = 2^{-1} \pi^{-1-1} \sin\left(\frac{\pi (-1)}{2} \right) \Gamma (1-(-1)) \zeta(1-(-1)) = \frac{1}{2} \left( \frac{1}{\pi^2} \right)(-1)(1)\left(\frac{\pi^2}{6}\right)=\frac{-1}{12}$$
We also know that people - often mistakenly - claim $1+2+3+4+...=-1/12$ through this result, since the summation of the natural numbers appears if you plug in $s=-1$ into the original sum, $\sum n^{-s}$.
This obviously isn't true - mistake aside, at least in what we consider the "usual topology of $\mathbb{R}$", the summation $1+2+3+...$ doesn't converge in
- The limit of its partial sums (which are the triangle numbers)
- The limit of the averages of its partial sums (Cesaro summation)
- Through Abel summation (per Wikipedia - I don't really know of this myself)
...and apparently a number of other summation methods (again, according to Wikipedia; I'm only familiar with the first two methods). Yet, interestingly...
Ramanujan's Summation of $1+2+3+...$:
Now, we know that in, the usual sense, we cannot assign a value to an obviously divergent series. For example, we cannot say $\sum a_n = x$ if this summation is divergent, and then perform manipulations on that as if it had a value, and try to deduce whatever $x$ is.
This doesn't always have to hold, just in the sense of the usual topology of the real numbers. (At least, this is what I was told by Thomas Andrews in the comments of an semi-related question here - related in the sense that it dealt with an "obviously divergent" product. I honestly don't know much about topologies.) I take this to mean that we can assign values to these "obviously divergent in the usual sense" summations, but it changes the context, the framework in which we're working.
So Ramanujan was essentially doing that, in a certain sense - implicitly considering an alternate topology of the reals, in which the summation over the naturals could be assigned a value $c$, i.e.
$$c = \sum_{n=1}^\infty n = 1+2+3+4+...$$
and then manipulating $c$ to try and determine its value. (At least, that's what he might have been doing, I'm not sure. He could've just been ignoring the topologies altogether and just seeing what he could do. Either way...)
Subtracting $4c$ from $c$, he obtained
$$-3c = 1-2+3-4+5-6+...$$
This summation is the expansion of the power series for $(1+x)^{-2}$ and thus, taking $x=1$, Ramanujan obtains
$$-3c = \frac{1}{(1+1)^2} = \frac{1}{4} \;\;\; \Rightarrow \;\;\; c = \frac{-1}{12}$$
So, The Question, and What I've Found:
So, by using the zeta function, we can show that $\zeta(-1) = -1/12$. Erroneously, people claim this as the sum of the natural numbers, but interestingly enough, Ramanujan showed that, if you can assign the divergent sum of the naturals a value, then it coincidentally is $-1/12$.
So, is there a connection between the Riemann zeta function - in particular its value at $s=-1$ - and Ramanujan's method of summing over the naturals? Is a mere coincidence? And in particular, why does Ramanujan's summation yield the same result?
I'm not really sure where to begin looking into this. Ramanujan's summation introduces the notion of a different topology on the reals, but I've never had a proper introduction into topology so I'm a bit loathe to go into learning a whole subject to understand a connection that might not even exist.
I did find that a Wikiepdia article on the summation $1+2+3+...$ kinda touches on a possible connection but I don't really buy it. (In the section on zeta function regularization, it suddenly starts considering the Riemann zeta function instead of the summation which seems more like a "similar but related" thing than establishing a proper connection.)
I mean, I understand where we're coming from in zeta function regularization, and I can sort of see it. We consider the summation over the naturals as a special case of the Riemann zeta function, then associate the value of the summation with the value of the zeta function there, or its analytic continuation if applicable. I can get that.
But it doesn't answer what I feel is the heart of my question:
I think more than anything, my big question is... Ramanujan's method relied nothing on "regularization" or "zeta functions" or any of this higher level stuff. He just assumed the summation had a value, and manipulated the summation to find that value. Yes, it broke some assumptions about the topology of the reals - that I myself don't understand well - yet somehow got the same answer that this regularization and all that would. How is it right? What is the connection?
The "obviously wrong" method somehow got the right answer. I mean, sure, it's right in the sense of the topology of the reals in which these manipulations are valid, but it's wrong in the usual sense. Yet it achieves the right answer.
So I think my biggest question is why it's correct. Coincidence? Perhaps the zeta function relies on likewise assumptions of topology that I've just not known about? I'm not really sure where to go from here; as it is my research is already broaching topics I know little to nothing about.
