The Muffin Problem
Definition Let there be $m$ muffins and $s$ students. The problem is to divide the muffins into pieces where every student gets exactly $\frac m s$ muffin, such that the size of the smallest piece you created while cutting the muffins is as large as possible.
Example For 3 students and 5 muffins, you could cut one muffin in half and the rest in $\frac 5 {12} + \frac 7 {12}$. Two students both get $\frac 1 2 + \frac 7 {12} + \frac 7 {12}$, the other student gets $\frac 5 {12} + \frac 5 {12} + \frac 5 {12}+ \frac 5 {12}$. Now the size of the smallest piece is $\frac 5 {12}$ which is larger than $\frac 1 3$ which corresponds to the trivial solution of cutting each muffin in three equal pieces.
The case of 5 students and 7 muffins
By trial and error we have found a solution where the size of the smallest piece is 1/3. In tabular form:
\begin{array}{r|ccccc} \text{Muffin}\backslash \text{Student} & 1 & 2 & 3 & 4 & 5 \\ \hline 1 & 1 &&&& \\ 2 & \frac 6 {15} & \frac 9 {15} &&& \\ 3 && \frac 7 {15} & \frac 8 {15} && \\ 4 && \frac 5 {15} & \frac 5 {15} & \frac 5 {15} & \\ 5 &&& \frac 8 {15} & \frac 7 {15} & \\ 6 &&&& \frac 9 {15} & \frac 6 {15} \\ 7 &&&&& 1 \\ \end{array} Notice the symmetry, and that one muffin is cut into three pieces which makes $\frac 1 3$ the smallest piece.
I happen to have looked in the original muffin paper by William Gasarch and page 160 reveils that $\frac 1 3$ is indeed optimal. (Note they have found no general formula yet, they only did some special cases.)
Question We now have a solution for this linear optimization problem, but how can we prove this solution is optimal?
Proof for 3 students and 5 muffins
The Muffin problem was coined in 2009 by Alan Frank, and a small article about this problem appeared recently in the Dutch newspaper NRC, following a muffin talk by Gasarch earlier this year. It contained a proof that for 3 students and 5 muffins, the solution of $\frac 5 {12}$ I gave above is optimal. I have tried to rewrite it leaving out all the pictures of muffins:
Proof We can assume that every muffin is cut into at least two pieces, because since at least one muffin has to be cut the smallest piece is at most $\frac 1 2$, so any entire muffin can be viewed as cut into two equal halves. There are two cases:
- Suppose there is at least one muffin being cut into 3 pieces. Then the smallest piece of that muffin is at most $\frac 1 3 < \frac 5 {12}$.
- Suppose all muffins are cut into exactly 2 pieces, so there are 10 pieces to be divided over 3 students. Therefore at least one student gets at least 4 pieces. Of those pieces, the smallest piece is at most $\frac 1 4 \cdot \frac 5 3 = \frac 5 {12}$.
PS Tagging MIP because Gasarch apparently claimed they used theorems from that field.
PPS My lecturer also found $\frac 1 3$ by rewriting it as a linear optimization problem and programming it in Sage, in itself an interesting task.
PPPS Fun fact, proven by Gasarch: when you have more muffins than students, the smallest piece is at least $\frac 1 3$.
Obviously I tried rewriting the proof for 3 students and 5 muffins, but I found it will have to have more cases because as the solution shows a muffin can be cut into 3 pieces without creating problems. But I couldn't figure out what to base the cases on. At least I found that if you cut all muffins into 2 pieces, you have 14 pieces so at least one student gets at most 2 pieces.
