Let $\Omega\subset \mathbb{R}^d $ be a bounded open subset ($d\in \mathbb{N}$) and denote $\partial\Omega$ its boundary which we assume to be Lipschitz. The classical inhomogeneous Neumann problem for Laplace operator associate to data $f:\Omega\to\mathbb{R}$ and $g: \partial\Omega \to \mathbb{R}$ (measurable functions) consists on finding a function $u:\Omega\to \mathbb{R}$ satisfying
\begin{equation}\label{eqlocal-Neumann}\tag{$N_1$} -\Delta u = f \quad\text{in}~~~ \Omega \quad\quad\text{ and } \quad\quad \frac{\partial u}{\partial \nu}= g ~~~ \text{on}~~~ \partial \Omega. \end{equation}
In the standard setting one usually choose $ f$ in $L^2(\Omega)$ or in the dual space of $H^1(\Omega)$ and $g$ can be choose in the trace spaces of $H^1(\Omega)$ denote by $H^{\frac{1}{2}}(\partial\Omega)$ or in its dual $H^{-\frac{1}{2}}(\partial\Omega)$.
Assume $f\in L^{2}(\Omega)$ and $g \in H^{3/2}(\Omega)$ then we have the following the Green-Gauss formula
$$\label{eqgreen-Gauss} \int_{\Omega} (-\Delta) u v \, \mathrm{d}x = \int_{\Omega} \nabla u \cdot \nabla v \, \mathrm{d}x- \int_{\partial \Omega} \gamma_{1} u \gamma_{0}v \, \mathrm{d}\sigma(x), \quad u\in H^{2}(\Omega) ~\hbox{and}~v\in H^{1}(\Omega). $$
Henceforth, on $\partial \Omega$ we merely write $\gamma_0 v= v$ and $ \displaystyle\gamma_1 v=\displaystyle \frac{\partial v}{\partial \nu} $.
Clearly from this green gauss formula, if $u\in H^{2}(\Omega)$ and solves \eqref{eqlocal-Neumann} then $u $ satisfies the variational problem
$$\label{eqlocalvar-Neumann}\tag{$V_1$} \int_{\Omega} \nabla u \cdot \nabla v \, \mathrm{d}x= \int_{\partial \Omega} f v \, \mathrm{d}x + \int_{\partial \Omega}gv \, \mathrm{d}\sigma(x), \qquad \hbox{for all } ~~v\in H^{1}(\Omega). $$ In particular if we put $v=1$ the above formulation becomes $$\label{eqlocalcompatible-Neumann}\tag{$C_1$} \int_{\Omega}f\mathrm{d}x+ \int_{\partial \Omega}g\mathrm{d}\sigma(x)=0 $$ which is the is the compatibility condition.
Viceversa we have the following global regularity result.
Theorem
Assume $\Omega\subset \mathbb{R}^{d}$ is bounded open with $C^2$-boundary. If a function $ u \in H^{1}(\Omega)$ is solution to \eqref{eqlocal-Neumann} with $f\in L^{2}(\Omega)$ and $g \in H^{3/2}(\partial\Omega)$ then it belongs to $ H^{2}(\Omega).$
Question: In which book or recommendable reference can I find the proof of the above theorem`? I know that the of this Theorem for the corresponding Dirichlet problem has been done in the book by Brezis or by Evans. Patently, both references avoid the inhomogenous Neumann problem.
Remark Moreover, observe that if $u$ solves \eqref{eqlocal-Neumann} or \eqref{eqlocalvar-Neumann} so does $\tilde{u} = u+c$ for every $c\in\mathbb{R} $ (that is invariant under additive constant).
Do you have a reference for the surjectivity of the Neumann trace?
– Lilla May 13 '22 at 12:30Here is what I am referring to: https://prnt.sc/cmczA3u0O2sD
– Lilla May 16 '22 at 12:26
