I know $\det(AB)=\det(A)\det(B)$. How can i prove using group theory if $A,B$ square matrices and I know $A, B\in GL(n,R)$. If the matrices were not square, it would be correct to say that it is valid?
Asked
Active
Viewed 218 times
2There are so many good answers in this question that I doubt you'll find anything new here. – krirkrirk Mar 11 '18 at 13:59
If the matrices are not square, then their determinants are not defined. Therefore, it definitely would not be correct to say that it is valid.
José Carlos Santos
- 440,053
Note that $$ det(AB)=det(A)det(B)$$ makes sense only for square matrices.
As you know, $det(M)$ is defined only when M is a square matrix M.
Mohammad Riazi-Kermani
- 69,891
