Suppose $L=\lim_{x\to0}\frac{1}{x}$ is finite.
If $L>0$, then there exists $\delta>0$ such that, for $0<|x|<\delta$, $|\frac{1}{x}-L|<L$, that is,
0<\frac{1}{x}<2L
This is a contradiction, just take $-\delta<x<0$.
Similarly if $L<0$.
Thus we can only have $L=0$. Then there should exist $\delta>0$ such that, for $0<|x|<\delta$, $|\frac{1}{x}|<1$, an obvious contradiction.
It can be neither $\lim_{x\to0}\frac{1}{x}=\infty$ nor $\lim_{x\to0}\frac{1}{x}=-\infty$, because $\frac{1}{x}$ assumes positive and negative values in every punctured neighborhood of $0$.
Can this be generalized? Not really. For instance, in order to show the non existence of $\lim_{x\to0}\sin\frac{1}{x}$ the easiest way is to show that the limit should be in the interval $[-1,1]$, but that $\sin\frac{1}{x}$ assumes every value in $[-1,1]$ in each punctured neighborhood of $0$, so it is far from every possible limit. Alternatively, there exist sequences $(a_n)$ and $(b_n)$ convergin to $0$ such that $\lim_{n\to\infty}\sin\frac{1}{a_n}=0$ and $\lim_{n\to\infty}\sin\frac{1}{b_n}=1$.
As another example, $\lim_{x\to0}e^{1/x}$ doesn't exist because the one sided limits are different: from the left it is $0$, from the right it is $\infty$.
