Let $f:\mathbb R^m \rightarrow [0,+\infty)\;$ be a smooth function that vanishes on a finite set $A\;$ where $\vert A \vert\; \ge 2$ and the maps $v:(l^{-},l^{+}) \rightarrow \mathbb R^m\;$ defined by
$\mathcal M= \{\;v\in W^{1,2}_{loc} (l^{-},l^{+});\;-\infty \le l^{-} \lt l^{+} \le +\infty\;,\;\lim_{x \to l^{-}} v(x)=a_1 \in A\;,\;\lim_{x \to l^{+}} v(x)=a_2 \neq a_1 \in A\;\;,\;v((l^{-},l^{+}))\subseteq \mathbb R \setminus A \}\;$.
Show that a minimizer of the functional $\;I(v)=\int_{l^{-}}^{l^{+}} \frac{{\dot v}^2}{2} + f(v) \;dx$ on $\;\mathcal M\;$ exists.
I found after some research the following theorem:
Let $\;X\;$ be reflexive, $\;M\subset X\;$ nonempty and weakly sequentially closed,$\; F:M\rightarrow \mathbb R \;$ coercive and weakly sequentially lower semi-continuous. Then there exist $\;x_0 \in M\;$ such that ; $\;F(x_0)=\inf_{x \in M} F(x)\;$
I know $\;W^{1,2}\;$ is reflexive and for the coerciveness of $\;I\;$ there is a hint: "Assume $\limsup_{\vert v \vert \to +\infty} f(v) \gt 0\;$" which I don't completely understand why is needed.
My question: How do I prove that $\; \mathcal M\;$ and $\;I\;$ satisfy the above theorem?
I'm really new to Sobolev Spaces and I hadn't seen before the term "weakly sequentially closed". I would appreciate if somebody could help me through this. Furthermore, any suggestions about useful books related to this topic, would be valuable.
Thanks in advance!!!
- You should have a theorem that assures you that a bounded sequence in $W^{1,2}(B)$ admits a weakly convergent subsequence, where B is an open set. You want to apply it to a minimizing sequence, unfortunately you cannot apply it directly since you are working in $W^{1,2}_{loc}(l^-,l^+)$.
– Uskebasi Apr 17 '17 at 11:18- you should have Tonelli's theorem that assures you lower semicontinuity (for functionals convex in $v'$). Again, in works only on bounded sets thus if $l^-=-\infty,\ l^+=\infty$ you have to fix an increasing sequence of compact sets contained in $(l^-,l^+)$, use the theorem in every compact set and try to pass to the limit with standard limit theorems
– Uskebasi Apr 17 '17 at 11:23
