22
I am starting to see a pattern in my math studies, and I'm interested in your thoughts on the subject.
It seems like there are certain things that are much easier for me to learn than others. For instance, I am a pretty quick learner when I can "visualize" what I'm learning, and logical thinking and rigid formalism seem pretty natural to me. I am also good with abstractions. On the other hand, I am painfully bad at calculations. I can make 5 mistakes when solving the simplest of equations (often not seeing my mistake even when I look for it, and then making 3 others when I try to fix it), and many mathematical tasks seem like meaningless symbol manipulations to me (calculating integrals, identities of all sorts, everything that involves unpleasant functions manipulations, complex numbers can reduce me to tears).
So, naturally I am a bit worried about my studies. Here are my questions:
  • I think there may be something I am missing. For the things I am good at, I often have a strategy: an abstraction or a certain way of thinking that helps me deal with them. Do you have such a strategy for dealing with the problems I mentioned? How do you start thinking about them?
  • How can I get better at these things? Trying really hard to do it a lot never seems to help. I just give up after making the same mistakes and reaching dead ends for two hours, look at the solution and don't understand how I could have come up with it on my own.
  • Is all lost? What can I do with the skills I have?
Thanks.
HNHN
  • 1,979
    I have the same problem myself. Integrals, solving systems of linear equations etc. have never been my strong side. I think it is just a question of education, and workings of the mind. I do not think I will ever be strong at "simple-math", but this is not essential for doing research. – utdiscant Feb 12 '11 at 22:26
    how about starting with simple mathematical calculations, try basic problems and solve it on your own... and increasing your confidence, when you have done some mistakes should think why you'd unintentionally done it and ... do the same problem/similar kind of problem again... – 911 Feb 12 '11 at 22:36
    It would help if you were more specific. Are you having trouble evaluating complicated integrals or all integrals? What kind of identities are you having trouble with? Are you having trouble remembering them or applying them? What is it about complex numbers that reduces you to tears? – Qiaochu Yuan Feb 12 '11 at 22:40
    This is what I learned about mathematicians through my B.Sc: They will go through lengthly definitions just to create a utility which allows you to ignore signs and scalars (namely Haar Measures). And god bless them for that! – Asaf Karagila Feb 13 '11 at 02:29
  • With regard to the mistakes: practice, practice, practice, and their number will decrease... The plan B is using a math program (I often just let Maxima to do the math for me...) – Calmarius Sep 22 '13 at 13:41
  • /wolfram alpha helps a little. So to does a copy of Mathematica students edition bought at a local university. When repetition gets tiresome, I stop and look at what I am doing. Are there any patterns? Can I do this in a different way? Why do I keep making THIS mistake? Can I think of a way to fix that?
    Calculators have made arithmetic unpopular. There are many advanced arithmetic books out there that provide an adult and more interesting way to look at an old subject. Could you approximate sin 32° without a calculator?
    – Steven Alexis Gregory Jun 04 '15 at 16:10
Mistakes in calculations plague mathematicians at all levels. Here's what Vladimir Arnol'd had to say about it:
"Every working mathematician knows that if one does not control oneself (best of all by examples), then after some ten pages half of all the signs in formulae will be wrong and twos will find their way from denominators into numerators."
The best way to catch mistakes in calculations is using 'sanity checks'. The most basic versions of these go back to elementary school (did you get a negative number for the volume?) and at the more advanced level you might plug in different values of x in your formula, let x go to infinity, etc. If you proved something about a group or a manifold, see what it gives you in a specific example. If you can think of another way to do the same calculation, that's best of all.
When you say "I just give up after making the same mistakes and reaching dead ends for two hours, look at the solution and don't understand how I could have come up with it on my own", it makes me think you're working on something too difficult. Find easier problems to work on first, build up your skills, and then come back to the harder problems later.
Also, keep poking around different subjects until you find where your strengths are. I've found in my own life that abstract algebra has always been and remains confusing and difficult. Calculus, differential equations, asymptotic analysis came much more easily. Complex analysis used to be torture, but now I've gotten pretty good at it and consider it one of my strengths. If something is really making you suffer, drop it for a while (maybe months or even years!) and then if necessary come back to it later when hopefully your increased mathematical maturity will make it easier.
Mathematics uses one thing: This is simply sticking to the definitions what already has been proved. The basic point is that you don't have to be a quick calculator in order to be good at math.
I can only agree with math postdoc: When I started learning differential geometry, I was more han confused. I wasn't able to perform the most simple calculations. But actually, that will become better and better as time passes.
If you rejoice in repetitive actions (as I do for instance) then it is a good way to keep repeting what you've learned so far, or what you're interested in all over again. I think I have read one book on differential geometry more than 10 times. After you have once read an entire book, deal with somehing different first, something that seems more difficult to you, then read the book you read initially again. Since you've already understood what it is about, your brain will start focussing on the things that are important for it, i.e., how to work with that stuff practically.
When I started with math (I was still at school - but due to external studies, I was able to work through a flexible mathematical curriculum.) and once had to calculate some volume integral, I had to spend one month on this exercise until, the day before a final chemistry exam, I came across the solution. I was so happy that I couldn't sleep anymore and was really tired during the exam so that I didn't score as a high as I regularly did.
blargen
  • 311
I have a method that helps me avoid errors. Of course it isn't perfect.
I bring up a text editor and enter the equation in some sort of ASCII form. Then I copy-paste the equation onto the next line and make a simple change. Then I copy-paste the result and make another simple change, etc.
Many of the changes one would make can be done with mindless operations on the text itself. For example, when you want to perform a distribution in the case of $a(b+c)$, highlight $a$, cut it to the clipboard, then paste it in front of all of the terms inside the parentheses. This simple example makes it look silly, but the method makes easy work of the most complicated expansions.
To factor something like $ax + bx$ or $a/x + b/x$, do these steps:
$ax + bx$
$ax + b)x$
$a + b)x$
$(a + b)x$
Another example is with expressions of the form $\mathrm e^a \mathrm e^b$. I represent them with "exp a exp b". Replace the second "exp" with " + " and put parentheses around the sum.
When you want to distribute a negative sign in the case of $-(a - b - c\space ...)$, add a negative sign in front of the quantity and in front of each term inside the quantity, like this: $--(-a--b--c\space ...)$ Then you can take away the parentheses. The triple minus becomes a single minus, and any double minuses become pluses.
Copy-paste makes it painless to do very simple steps, and eliminates the possibility of copy errors. Stupid mechanical rules reduce the chance of arithmetic errors.
I dunno. Hope this helps.
MackTuesday
  • 1,077
