In my book the result $$(u\times v)\cdot(x\times y)=\begin{vmatrix} u\cdot x & v\cdot x \\u \cdot y & v \cdot y\end{vmatrix},$$ where u, v, x and y are arbitrary vectors, is stated (here '$\cdot$' means the dot product and '$\times$' is the cross product). The book very briefly says that this can be easily done by observing that both sides are linear in u, v, x and y.
I know that if I expand and simply the LHS using the components of a vector the result will be true. However, I don't really understand what it means when the book says ' both sides are linear in u, v, x and y ' and how by noticing this fact, makes this relation easier to prove.
Any help will be greatly appreciated.
MJD
  • 67,568
  • 43
  • 308
  • 617
It means that you can verify the relation just using the standard basis $\{e_1, e_2, e_3 \}$ of three dimensional space. For example you should check $(e_1 \times e_2)\cdot (e_2 \times e_3) =0$ which is the same as the right hand side.
PAD
  • 4,253
  • I'm gonna mull over this; atm I don't really see why it suffices to just verify the relation using the standard basis. – SomethingWitty Oct 09 '12 at 14:43
  • @SomethingWitty - because any vector is a linear combination of elements of the standard basis, and the function you are computing is linear in each place. – Mark Bennet Oct 09 '12 at 15:09
    Any vector is a linear combination of these three basis elements. If a relation is linear, it is enough to verify it on just one basis of the vector space. Suppose you want to show $u\cdot v=v\cdot u$. If it is correct on the $e_i$ then write $u$ and $v$ as linear combinations of the $e_i$, use linearity and you will see the result. – PAD Oct 09 '12 at 15:14
Suppose we have two linear functions, $f$ and $g$, which agree on all the basis vectors of some space. Then they must agree for every vector on that space, because they are both linear, and a linear function is completely determined by its values on the basis.
In gory detail, suppose that we know that $f(\vec{e_i}) = g(\vec{e_i})$ for each basis vector $\vec{e_i}$.
Consider some vector $\vec v$. We can express $\vec v$ a a linear combination of basis vectors, say as $$\vec v = c_1\vec{e_1} + \cdots + c_n\vec{e_n}.$$ Then we know that $$\begin{align} f(\vec v) & = f(c_1\vec{e_1} + \cdots + c_n\vec{e_n}) \\ & = c_1f(\vec{e_1}) + \cdots + c_nf(\vec{e_n}) & \text{(linearity of $f$)} \\ & = c_1g(\vec{e_1}) + \cdots + c_ng(\vec{e_n}) & \text{($f=g$ for basis vectors)} \\ & = g(c_1\vec{e_1} + \cdots + c_n\vec{e_n}) & \text{(linearity of $g$)}\\ & = g(\vec v) \end{align} $$
One can similarly show an analogous fact for functions of several variables. For example, if $f(u,v,x,y)$ and $g(u,v,x,y)$ are linear functions of $u, v, x,$ and $y$, and if they agree on all combinations of the basis vectors for some space, then they agree on every vector in that space.
Now take $f(u,v,x,y) = (u\times v)\cdot(x\times y)$ and $g(u,v,x,y) =\begin{vmatrix} u\cdot x & v\cdot x \\u \cdot y & v \cdot y\end{vmatrix}$. These are easily seen to be linear, or easy to show to be linear if you don't see it, using properties of cross and dot products (for $f$) and of determinants and dot products (for $g$). So if you can show that they are equal when $u,v,x,$ and $y$ are basis vectors, you are done. And for most choices of basis vectors as arguments, both sides are equal to zero, so this is quick to verify.
MJD
  • 67,568
  • 43
  • 308
  • 617
