We want to be able to compute discrete logarithms with basis $a = 89$ in $\mathbb{Z}^*_p$ for $p = 1235789.$ We choose the factor base $B = {−1, 2, 3, 5, 7, 11, 13, 17, 19, 23}$. With the first step of Index Calculus algorithm I get this system of linear equations.
\begin{bmatrix}0&3& 0& 2& 0& 0& 2 & 0 & 0 & 1 & 100058\\ 1&1&1&0&0&0&1&0&0&3&100131\\0&4&3&0 & 0 & 1 & 0 & 0 & 1 & 0 & 100152 \\ 1 & 6 & 3 & 1 & 0 & 1 & 1 & 0 & 0 & 0 & 100232\\ 1 &2 &3 & 0 & 1 & 2 & 1 & 0 & 0 & 0 & 100343 \\ 1 & 2 & 7 & 0 & 1 & 0 & 1 &0 & 0 & 0 & 100360\\ 1 & 5 & 2 & 1 & 2 & 0 & 0 &1 & 0 & 0 & 100385\\ 1 & 6 & 2 & 1 & 0 & 0 & 0 & 1 & 0 & 1 & 100401\\ 0 & 0 & 4 & 0 & 3 & 0 & 0 & 1 & 0 & 0 & 100412\\ 0 & 0 & 5 & 0 & 1 & 0 & 0 & 1 & 0 & 1 & 100428 \end{bmatrix}
Then I use Gauss's elimination to solve the equations.
\begin{bmatrix} 1& 0& 0& 0& 0& 0& 0& 0& 0& 0& -494241/70\\ 0& 1& 0& 0& 0& 0& 0& 0& 0& 0& 250358/35\\ 0& 0& 1& 0& 0& 0& 0& 0& 0& 0& 250358/35\\ 0& 0& 0& 1& 0& 0& 0& 0& 0& 0& -1749/10\\ 0& 0& 0& 0& 1& 0& 0& 0& 0& 0& 498777/35\\ 0& 0& 0& 0& 0& 1& 0& 0& 0& 0& 1000837/70\\ 0& 0& 0& 0& 0& 0& 1& 0& 0& 0& 2015443/70\\ 0& 0& 0& 0& 0& 0& 0& 1& 0& 0& 1016657/35\\ 0& 0& 0& 0& 0& 0& 0& 0& 1& 0& 2504791/70\\ 0& 0& 0& 0& 0& 0& 0& 0& 0& 1& 747756/35\\\end{bmatrix}
I'm having problems understanding why is my solution of linear equations not correct?
Edit: What is the correct way to use guass's elimination with$\mod p - 1$?
Cave Johnson
  • 4,360
For index calculus, you need to do linear algebra mod $p - 1$. So you can't use ordinary linear algebra methods for the real numbers, since things like division won't work properly.
As it turns out, you can do linear algebra in any field, because a field supports addition, subtraction, multiplication, and division (multiplication by the inverse). Unfortunately, the integers mod $p - 1$ aren't a field. Only the integers modulo a prime are a field, but $p - 1$ isn't prime (unless $p = 3$). So you need to turn your problem modulo $p - 1$ into one or more problems modulo primes.
To do this, factor
$$ p - 1 = \prod_{i} q_i^{e_i}, $$
where the $q_i$ are prime and distinct. Then solve the system modulo each of the $q_i$, lift these solutions to $q_i^{e_i}$, and finally use the Chinese Remainder Theorem to get a solution modulo $p - 1$.
ameed
  • 346
