9
Are there any formula for result of following power series? $$0\leq q\leq 1$$ $$ \sum_{n=a}^b q^n $$
cineel
  • 1,547
  • 11
  • 23
Muaa2404
  • 303
4 Answers4
12
Yes, consider the following manipulation: $$ S = \sum_{n=a}^b q^n = q^a + q^{a+1} + \cdots + q^b = q^a + q(q^a + a^{a+1} + \cdots + q^{b-1}) = q^a + q(S-q^b). $$ Solving this we find that .... $$ S = \frac{q^a-q^{b+1}}{1-q} $$
Lionel Ricci
  • 1,828
Yes. $$ \sum_{n = a}^{b} q^{n} = \sum_{n = 0}^{b} q^{n} - \sum_{n = 0}^{a-1} q^{n}. $$ Now, if $M$ is either $a-1$ or $b$, and if $q<1$ then $$ \sum_{n=0}^{M} q^{n} = {1 - q^{M+1} \over 1 - q} $$ The last formula is explained here: https://en.wikipedia.org/wiki/Geometric_series#Formula
And if $q=1$, then $q^{n} = 1$ for all $n$.
avs
  • 6,410
  • $q$ cannot be 1. –  Nov 03 '16 at 19:02
  • The OP says, $0 \leq q \leq 1$. And, I hope your nickname is commensurate with your actual publication record. – avs Nov 03 '16 at 19:18
  • The OP ignores the existence of the Geometric Series, hence it ignores the radius of convergence of the same. Which means that you shall have told him that the series diverge for $q = 1$. –  Nov 03 '16 at 19:19
First we assume $a \le b$ (otherwise we swap). With $$ S = \sum_{k=a}^b q^k $$ If $q=1$ we have $S=b - a + 1$. For $q < 1$ we have $$ q S = \sum_{k=a}^b q^{k+1} = \sum_{k=a+1}^{b+1} q^k = S + q^{b+1} - q^a \iff \\ q^a - q^{b+1} = (1-q) S $$ This gives $$ S = \begin{cases} b - a + 1 & \text{ for } q = 1 \\ (q^a-q^{b+1})/(1-q) & \text{ for } q < 1 \end{cases} $$
mvw
  • 35,114
I know people have already answered this, but laying out each step one-by-one helped me, I hope it helps y'all too,
Take,
$$ S = \sum_{k=a}^b p^k $$
Expanding it,
$$ S = p^a + p^{a+1} + ... + p^{b} $$
Taking $p$ out,
$$ S = p^a + p (p^{a} + p^{a+1} + ... + p^{b-1}) $$
Now add & subtract $p^{b}$,
$$ S =p^a + p (p^{a} + p^{a+1} + ... + p^{b-1} + p^b - p^b) $$
We recognize $S$ & substitute to get,
$$ S =p^a + p (S - p^b) $$
Distribute,
$$ S=p^a + pS - p^{b+1} $$
Rearrange,
$$ S(1 - p) =p^a - p^{b+1} $$
Finally,
$$ S =\frac{p^a - p^{b+1}}{1 - p} $$
