10
In my book the following definition is given:
A category $C$ is called small if both the collection of objects and arrows are sets. Otherwise the category is called large.
A set is delfined to be a collection of distinct objects. Now I am a little confused since the category of all finite sets is said to be small, which is ok for me since the objects and functions can be considered as sets. But why isn't the category of groups a small category? All groups may be considered as distinct objects and hence a set, same argument goes for group homomorphisms. Can someone explain why I am so confused here?
Mat
  • 139
    Contrary to the claim, the collection of finite sets is not a set! In fact, for every set $S$, the set ${S}$ is a distinct finite set. – Hagen von Eitzen Dec 26 '22 at 13:04
The main source of confusion is the definition of a set as "a collection of distinct objects". Such definition leads to Russell's paradox and Cantor's paradox, which are usually overcome through adopting an axiomatic set theory.
In order for one to talk about small and large categories, one first needs to specify the adopted foundations of category theory. There are several foundations in which categories can be defined, the most frequently used is Zermelo-Fraenkel set theory with the axiom of choice (ZFC) and the axiom of the universe. In these settings, you can distinguish two different types of set-theoretical objects, namely (small) sets and proper classes, with respect to a given universe. There are some interesting and subtle differences between sets and proper classes, one which is the size difference. All the set-theoretical objects that are bigger than the chosen universe are proper classes.
The category $\mathbf{FSet}$ of finite sets and their maps is small (with respect to an uncountable universe), because the axioms of ZFC and the uncountable universe imply that both $\mathop{\mathrm{Ob}}(\mathbf{FSet})$ and $\mathop{\mathrm{Mor}}(\mathbf{FSet})$ are small sets. However, $\mathop{\mathrm{Ob}}(\mathbf{Grp})$ is bigger than the universe, i.e. it is a proper class, and hence $\mathbf{Grp}$ is not small.
One reason to care about having small or large categories, is that not all constructions that work for small categories work for large categories. For instance, in some foundations, the functor category $\mathbf{Fun}(\mathcal{C},\mathcal{D})$ exists when $\mathcal{C}$ is small, but not necessary when it is large.
To read more about this subject, you may start with the foundations, and refer to the other links.
P.S. Some sources refer to what is called here set-theoretical object simply by set, and emphasise the word small in the name of small sets, to make the distinction.
In set theory (ZFC), you cannot construct the set of all sets. That's why the need to distinguish between big and small categories: in the big ones you cannot use some machinery, otherwise we would run into some problems like Russel's Paradox.
Since the underlying set of a group is a set, you cannot construct the set of all groups as well. You can though construct the set of all finite groups (say, that are subsets of $\mathbb{N}$).
PenasRaul
  • 1,224
  • The first sentence of the second paragraph does not work: the underlying set of a finite group is also a set. To fix this, it suffices to show that, for every infinite set S, there exists a group structure on it. – Yai0Phah Dec 26 '22 at 13:07
  • Re your last paragraph: It is not enough that the underlying set of a group is a set. (Or else, your argument suggests that the class of empty sets is not a set). Rather, We can define a group structure on every non empty set and therefore have “too many” groups. Alternatively, we get those “too many” from the free groups generated by arbitrary sets – Hagen von Eitzen Dec 26 '22 at 13:08
  • @Yai0Phah There is no set of all finite groups/sets, either – Hagen von Eitzen Dec 26 '22 at 13:10
