so i have a possibly singular coefficient matrix A . (it's sometimes singular and sometimes not !) (in the case of singularity it has many solutions we only need one)
i know using an inverse to find the answer to a system of linear equations is an awful idea .
so it seems even in this case we should use methods like Gauss-Jordan to solve the system even when it is singular . is there any method to solve singular systems like Gauss-Jordan.(to give a answer)
and i read the matlab document on solving this types of systems and it says that we should use the pseudo-inverse function pinv like : x = pinv(A)*b
this just looks as awful as taking the inverse (since for a non-singular matrix pseudo-inverse is same as inverse). (am I correct?)
and is it the case that we don't have any other more efficient choices of finding and answer in this case ??
dantopa
  • 10,768
KFkf
  • 846
It is not generally true that the pseudoinverse is the same as the inverse. In the case that a matrix is invertible, then they coincide. The pseudoinverse can be computed in different ways; pinv in MATLAB is generally good at selecting the right algorithm for the job (typically something SVD-like).
It's important to note that for a singular or otherwise ill-conditioned problem, the resulting value will not necessarily represent the solution, but rather the solution that minimizes the value $\| Ax-b\|$.
Emily
  • 36,334
  • To amplify the comments of @Emily: http://math.stackexchange.com/questions/1537880/what-forms-does-the-moore-penrose-inverse-take-under-systems-with-full-rank-ful/2200203#2200203 – dantopa Mar 24 '17 at 14:45
The answer is framed using the tools in Mathematica, which are the most familiar set. The translation to MATLAB or Octave, etc., should be direct.
Given a system matrix $\mathbf{A}$ and a data vector $b$, solve the linear system $$ \mathbf{A} x = b $$
The first attempt is to try a direct linear solution
x=LinearSolve[A,b]
You can trust the application, or you can specify a solution method. Current options are
  1. banded matrix solver
  2. Cholesky method for positive definite Hermitian matrices
  3. iterative Krylov sparse solver
  4. direct sparse LU decomposition
    Next, try for a least squares solutions
x = LeastSquares[A, b]
This opens the door for the experts who have written the application which chooses a good method for solution.
If there is no solution, we have learned that the data vector is in the null space.
Of course, there is the pseudoinverse solution
x = PseudoInverse[A].b
As noted by @Shiyue in his post What is the best way to compute the pseudoinverse of a matrix?, the application writers use fast methods to assemble the pseudoinverse.
There are slower options. One is to construct the pseudoinverse manually.
{u,s,v}=SingularValueDecomposition[A] x = v.PseudoInverse[s].ConjugateTranspose[u].b
The $\mathbf{QR}$ decomposition:
{q,r}=QRDecomposition[A] x = PseudoInverse[r].Conjugate[q].b
dantopa
  • 10,768
