11
Tennenbaum's theorem does not apply to Robinson Arithmetic ($Q$). There is a computable, nonstandard model of $Q$ "consisting of integer-coefficient polynomials with positive leading coefficient, plus the zero polynomial, with their usual arithmetic."
What is an example of how the first order induction schema fails in a computable, nonstandard model of $Q$? Can such a model have a predicate, in the language of Q, that is only true for standard natural numbers and false for "infinite" natural numbers? Can a computable nonstandard model have overspill?
Given the model above, what is an example of a statement, in the language of $Q$, that is true for the zero polynomial and all successors of the zero polynomial and false for some other polynomial in the model?
Here's an even simpler one: "Every number is either even or odd." That is, $$\forall x\exists y(x=y+y \mbox{ or } x=y+y+1).$$ The polynomial $x$ is a counterexample.
Ignoring the specific model and focusing on the theory, it's also worth noting that Robinson arithmetic doesn't even prove that addition is commutative or that the successor of a number is different from that number! (If I recall correctly, this is covered in Burgess' book Fixing Frege - see a review at http://www.utexas.edu/cola/_files/iaa4774/On_Burgess_Fixing_Frege.pdf.)
EDIT: Now that I look more closely, this is basically all covered in the wikipedia page on Robinson arithmetic, in the section "Metamathematics"; I suggest you read it and the linked references.
FURTHER EDIT: Here's even more statements, with easy induction proofs, that Robinson doesn't believe! :P (Note that these do in fact hold in the specific model in the OP.)
  • $\sqrt{2}$ is irrational.
  • There are infinitely many primes. More precisely, "for every $x$ there is a prime $>x$."
  • Unique factorization into primes.
See Francois Dorais' answer to https://mathoverflow.net/questions/19857/has-decidability-got-something-to-do-with-primes.
Noah Schweber
  • 260,658
  • Perhaps it is worth pointing out that "There are infinitely many primes" is formulated as "There is always a bigger prime", so when you say there are infinitely many primes can be false what you mean is that the set of primes is bounded. – Asaf Karagila May 28 '16 at 05:48
  • @AsafKaragila That's a good point - fixed. – Noah Schweber May 28 '16 at 05:48
Here is another example, $$\forall x(S(x)\neq x)$$
It holds for $0$, and if it holds for $x$, then it holds for $S(x)$ as well. But it is possible to have a model with an element which is its own successor.
Asaf Karagila
  • 405,794
    Note, however, that this doesn't provide an example for the specific model the OP mentions. – Noah Schweber May 28 '16 at 05:33
  • Sure, but also note that the question is "What is an example of how the first order induction schema fails in a computable, nonstandard model of $Q$?", and there are many computable nonstandard models of Q. – Asaf Karagila May 28 '16 at 05:46
  • Yes - I didn't want to give the impression that I thought this was a bad answer, I just wanted to clarify for the OP. – Noah Schweber May 28 '16 at 05:47
For a sentence true for the ordinary natural numbers, but false in the polynomials described above, we can use $$\forall w\exists y_1\exists y_2\exists y_3\exists y_4(w=y_1^2+y_2^2+y_3^2+y_4^2),$$ since by a result of Lagrange every non-negative integer is the sum of $4$ squares, but the polynomial $x$ is not a sum of $4$ squares of polynomials.
André Nicolas
  • 514,336
