Let V be a $\mathbb{Z}[i]$-module generated by elements $v_1$ and $v_2$ with the following relations:
$$ (1+i)v_1+(2-i)v_2=0 $$ and $$ 3v_1+5iv_2=0 $$
I need to write V as a sum of cyclic modules. I tried to do this the basic way: putting the matrix $$ \left[\begin{array}{cc}1+i&2-i\\3&5i \end{array} \right] $$ in the Smith form $$ \left[\begin{array}{cc}1&0\\0&-11+8i \end{array} \right] $$ Now, by the Structure Theorem, we have that $V$ is isomorphic to $\frac{\mathbb{Z}[i]}{\langle 3-19i\rangle}$, which is cyclic because $\langle 3-19i\rangle$ is an ideal of $\mathbb{Z}[i]$. Therefore nothing more needs to be done.
Is that correct?
Dietrich Burde
  • 140,055
Marra
  • 5,039
  • Dear Gustavo, I think there is an error in your computations. E.g. the determinant of the original matrix is $-11 + 8i$, which is not the same as $3 - 19i$ (even up to a unit). Regards, – Matt E Jul 04 '12 at 04:01
    Ok, I'm going to make my calculations again. Regardless, can you tell me if the idea is correct? – Marra Jul 04 '12 at 05:11
  • Dear Gustavo, Yes, the idea is correct. Regards, – Matt E Jul 04 '12 at 13:25
    I made my calculations again, I noticed that in one particular step I was multiplying a row by a factor which was not an unit (in $\mathbb{Z}[i]$); now the result is the matrix $$\left[\begin{array}{cc}1&0\0&-11+8i\end{array}\right]$$ just as you pointed through the determinant. Thus the result is that V is isomorphic to $\frac{\mathbb{Z}[1]}{<-11+8i>}$. Thanks! – Marra Jul 04 '12 at 20:12
    Dear Gustavo, You're welcome. I am writing an answer reflecting our exchange in the comments, just so that this question can move from the unanswered to the answered category. Best wishes, – Matt E Jul 05 '12 at 02:52
Here is an answer, based on the discussion in the comments:
The method is correct, but there was a calculation mistake. The correct answer is that the module $V$ is isomorphic to $\mathbb Z[i]/\langle -11 + 8i \rangle.$
Matt E
  • 127,227
