Question 1 Show that floating point arithmetic sums $$s_n=\sum_{k=1}^n\frac{1}{k^2} = 1+\frac{1}{2^2}+\frac{1}{3^2}+\dotsb+\frac{1}{n^2}$$ with accuracy $\mathcal O(n)\epsilon$ from left to right, while summing from right to left gives accuracy $\mathcal O(\log n)\epsilon$.
Source.
There is an example of summing 5, 10, 15 $\left(\left(5+10\right)\left(1+\epsilon\right)+15\right)\left(1+\epsilon\right) =30+45\epsilon$ $\left(\left(15+10\right)\left(1+\epsilon\right)+5\right)\left(1+\epsilon\right) = 30+55\epsilon$
Where does the form $\left(1+\epsilon\right)$ come from? And any suggestion on how to approach this problem? thanks!
Em.
  • 16,196
J.doe
  • 1,437
You get it from $$ fl(a+b)=(a+b)(1+\delta) $$ with $|δ|\leϵ$ the quasi random relative error of the floating point execution of the operation.
In computing $s_n=\sum_{k=1}^n a_k$ via the partial sums $s_{m+1}=s_m+a_{m+1}$ each numerical step produces an error $Δs_m$ that accumulates as $$ s_{m+1}+Δs_{m+1}=fl(s_m+Δs_m+a_{m+1})=(s_m+Δs_m+a_{m+1})(1+\delta_m) $$ The errors are dominated by the first order terms, so that up to higher order terms after removing the exact terms one gets $$ Δs_{m+1}=Δs_m+s_{m+1}\delta_m $$ So in first order of approximation, the last error added to the sum is proportional to the sum up to date, which in total gives $$ Δs_n=s_2\delta_1+s_3\delta_2+…+s_n\delta_{n-1}. $$
The quasi random quantities $\delta_m$ are bound by a machine constant $ϵ$. The partial sums have the absolute sums as upper bound. Combining both one gets $$ |Δs_n|\le \sum_{k=1}^n (n+1-k)·|a_k|\,·\,ϵ $$
For the sum $\sum_{k=1}^n\frac1{k^2}$ summing from the front gives $a_k=\frac1{k^2}$ and the first order coefficient of the error term $$ \sum_{k=1}^n (n+1-k)·|a_k|=(n+1)\sum_{k=1}^n\frac1{k^2}-\sum_{k=1}^n\frac1k\le(n+1)\frac{\pi^2}6-\ln(n+1)=O(n) $$
Summing from the end is encoded as $a_k=\frac1{(n+1-k)^2}$ which gives the first order coefficient of the error term as $$ \sum_{k=1}^n\frac1{n+1-k}\le 1+\ln(n)=O(\log n) $$
The identities used are $$ \sum_{k=1}^n\frac1{k^2}\le\sum_{k=1}^\infty\frac1{k^2}=\frac{\pi^2}6 $$ and, as an easy consequence of $e^x\ge 1+x$ or bounds on $\int_{k-1}^k\frac1x\,dx$, $$ \ln(k+1)-\ln(k)\le \frac1k\le \ln(k)-\ln(k-1)\\ \ln(n+1)-\ln(1)\le\sum_{k=1}^n\frac1k\le 1+\ln(n)-\ln(1) $$
Lutz Lehmann
  • 131,652
  • Does p represent the portion of the error and the sum? But why we add $1/(p^2)$ all the way to $1/n^2$? If we add from right to left, isn't the first term $1/n^2$? – J.doe Jan 31 '16 at 19:28
  • The first summation is $\frac1{n^2}+\frac1{(n-1)^2}$. I assumed that the question is only about the error of the summation, not the computation of the terms. The error formula for the last 3 terms is $((a_n+a_{n-1})(1+δ{n-1})+a{n-2})(1+δ{n-2})$ etc., so that the coefficient for $δ_p$ is $a_n+a{n-1}+…+a_p$. – Lutz Lehmann Jan 31 '16 at 19:38
  • Isn't the coefficient of $\delta_{n-2}$ is $\left(a_n+a_{n-1}+a_{n-2}+\left(a_n+a_{n-1}\right)\delta_{n-1}\right)$? Or are you saying we can ignore $\left(a_n+a_{n-})\right)\delta_{n-1}$ this part somehow? – J.doe Jan 31 '16 at 19:59
  • Yes, ignore. For error estimates, one is only interested in the first order terms, as one has to add a lot of size $\mu^2$ terms to get a contribution of magnitude $\mu$, as $\mu=2^{-53}<10^{-15}$. – Lutz Lehmann Jan 31 '16 at 21:07
  • Thanks! One more question, when you were summing the error, you ignored the part $-(1/n)$, why is that? And can i just say that $1/p$ is the error for $\delta_p$? – J.doe Jan 31 '16 at 21:14
  • Because in the end, one is interested in an upper bound. One could take them into consideration to get $(\ln(n)-1)ϵ$ as upper bound, but that is still $O(ln(n)⋅ϵ)$. – Lutz Lehmann Jan 31 '16 at 21:20
  • And we can just say that $O\left(ln\left(n\right)\cdot\epsilon\right)$ = $O\left(log\left(n\right)\cdot\epsilon\right)$? – J.doe Jan 31 '16 at 21:25
  • Yes. Because the difference between $\ln x$ and $\log_c(x)=\ln(x)/\ln(c)$ is a constant factor. – Lutz Lehmann Jan 31 '16 at 22:03
  • Changed/updated the hints to a full and coherent answer. – Lutz Lehmann Feb 04 '16 at 12:29
