$f:[0,1]\times [0,1]\to\mathbb R,$ defined by $$f(x,y)= \begin{cases}1,\quad \ \ y\in\mathbb R\text{\\}\mathbb Q\\2x,\quad\text{otherwise}\end{cases}$$.
$1.1$: $\int_0^1f(x,y)dx$ exists for every $y\in[0,1]$ and is equal to $1$.
$1.2$: The iterated integral $\int_0^1(\int_0^1f(x,y)dx)dy$ exists and is $1$.
$1.3$: The double integral $\int_If(x,y)d(x,y)$ does not exist.
I am struggling with solving iterated integrals in general and with this one I don't even know where to start since the values kind of jump from 1 to 2x constantly.
Edit: Got an idea for 1.1.: I made two cases, one for an irrational y and one for the rest. Giving me $\int_0^11dx$ which is 1 and $\int_0^12xdx$ which also is 1.
Could someone give me a short explanation about them and some hints on how to approach these exercises?
Rab
  • 395
You will probably want to use Lebesgue's criterion for Riemann integrability: it works quickly for 1.1 and 1.2. For 1.3 you might want to note that there is a version of this criterion for functions of several values too (which essentially says the same: a bounded function is Riemann-integrable $\iff$ it is continuous almost everywhere). Therefore, in fact, your problem is less one on integration and more one on continuity.
Alex M.
  • 35,927
First notes:
(1) have you solved correctly.
For (2) you can plug in your solution $\int_0^1f(x,y)dx=1$ into the integral $\int_0^1\int_0^1f(x,y)dxdy$ to get $\int_0^11dy$ which you can solve easily...
For (3) have a look at Is Dirichlet function Riemann integrable? and https://math.stackexchange.com/a/1167830/32951 (I guess you have to consider the Riemann not the Lebesgue integral)
