note for the unfortunate reader: my native language is not English so I apologize in advance for errors
the references link seems to be fixed now
On non-integer rank Hyperoperations
When you ask if values of $G(n,-,-)$ can be provided if $n\in\Bbb Z $ or $n\in \Bbb R$ you are actually asking if is possible to define an extension of $G$ to the integers, rational or real numbers (or complex) satisfying the Hyperoperations recursion over all the domain.
Brief introduction
Notation 1: With $G:\Bbb N\times\Bbb N\times\Bbb N\to\Bbb N$ we mean the Goodstein function [1] or equivalently the Hyperoperations sequence: let's work with $G$ (a $3$-ary function) as if it is an indexed family of binary functions $+_{s\in \Bbb N}:\Bbb N \times \Bbb N \to \Bbb N$ and call the index $s$ the rank of the hyperoperation.
$$m+_s n:=G(s,m,n)$$
Notation 2: The infix notation that I'm using ($+_s$) is not common at all, as the Goodstein $G$. Usually the most common notations for $+_s$ are $H_s$ (Wikipedia page prefix notation) or $[s]$ (Square bracket infix notation) or maybe $A_s(m)=2[s]m$ (comes from the Ackermann function and is used in some recursion papers about the Grzegorczyk hierarchy and in some recent works of D. Kouznetsov [6]) and the Knuth's Uparrow notation $\uparrow^n$ (that has a different indexing starting from $\uparrow^0=\times$) [2]
$$H_s(x,y)=x[s]y=x\uparrow^{s-2}y=G(s,x,y)=x+_s y$$
Definition 1 (Hyperoperations sequence): We define the indexed family $\{+_s\}_{s\in \Bbb N}$ recursively over the natural numbers ($b,n, s\in \Bbb N$)
$i) $ $b+_0n=n+1$
$ii)$ $b+_{s+1}0=b_{s+1}$
$iii) $ $b+_{s+1}(n+1)=b+_s(b+_{s+1}n)$
Where base values $b_{s+1}$ that give us the "natural/classical" hyperoperations sequence are the following
$iv)\,\,\,\, b_ {s+1}:= \begin{cases} b, & \text{if $s=0$} \\ 0, &
\text{if $s=1$ } \\ 1, & \text{if $s\gt 1$ } \\ \end{cases}$
I will call the argument $b$ base, $s$ rank and $n$ exponent.
Remark 0 Note that this definition gives us the "standard" hyperoperations
$H_1(x,y)=x+_1y=x+y$
$H_2(x,y)=x+_2y=xy$
$H_3(x,y)=x+_3y=x^y$
$H_4(x,y)=x+_4y={}^{y}x$ (Tetration)
Terminology 1: About the use of the term rank for the argument $s$ I don't think that is official but at least it makes sense for various reasons. As far as I know the term was introduced by K. A. Rubtsov and G.F Romerio in different papers/reports for the first time since the year 2006 [3] (p.3) and the term has been widely adopted by the Tetration Forum in the subsequent years. Another good reason is that every Hyperoperation $H_n$ belongs to the class $\mathcal E^n$ of the Grzegorczyk Hierarchy [4], a Sub-recursive hierarchy that organizes the Primitive Recursive functions according to their growth rate. Since the position inside a hierarchy is usually denoted by the term rank (See $V_\alpha$ hierarchy of sets for example) it seems to me a perfect choice. About the base and exponent terms I'm not sure, Rubtsov and Romerio tried to introduce, and used systematically, the the terms hyperbase for $b$ and hyperexponent for $n$ together with an uniform terminology for right and left inverse hyperoperations [5].
Remark 1: This sequence follows from original Goodstein definition and it implies that the $0$-th rank hyperoperation trivially coincides with the successor function $a+_0 n=n+1$ and so does all the integers-negative ranks: you can find more about this in the good David K answer here, in my and Ibrahin Tencer's answers here [7] and on the Tetration Forum [8] Anyways it is possible to avoid the imposition of $a+_0 n=n+1$ with alternative definitions of the hyperoperations sequence that give us more freedom for the negative ranks: about this there is a large amount of work by Rubtsov and Romerio under the name of Zeration [3], [9], [10] and by Cesco Reale in [11]. The topic is quite controversial and not very well known so I suggest you those two thread on TetrationForum [12], [13]
Back to your question, Imho is important to notice that is unlikely that you can extend the rank to non-ingers values without finding a way to extend the base and the exponent too. If you look at the sequence $x_s:=2+_s n$, for a fixed $n$ , we have that $x_s\in \Bbb N$ if the rank is a natural number but if we want it to be continuous or analytic in the variable $s$, thus extending to $s \in \Bbb R$, is very likely that for most of the non-integers ranks $x_s$ will have non-integer values making the functions $+_s$ not closed on the naturals for most of the non-integers ranks even when the base and exponent are natural numbers.
Example: if $2+_{1.5}3=q$ and $q\in \Bbb R\setminus \Bbb Z$ then evaluating $2+_{1.5}4=q$ would need to know how to evaluate $2+_{0.5}q$
That's my impression.
The higher-order function iteration approach
An interesting way to continue [14] is to look at some suitable space of binary functions $\mathcal H$ with $+_s\in\mathcal H$ together with a function $\Sigma:\mathcal H\to \mathcal H$ with the following property
$$\Sigma [+_s]=+_{s+1}$$
and continue investigating its dynamics because it turns out that the Hyperoperations are the natural iterations of this map $\Sigma$ applied to the $0$-th rank hyperoperation
$$\Sigma^{\circ n}[+_0]=+_n$$
The operator $\Sigma$ increases by one the rank of the hyperoperations so it's plausible to expect that the fractional/real/complex iteration of this map Is going to give us the fractional/real/complex rank hyperoperations:
$$\forall \sigma\in \Bbb C(\Sigma^{\circ \sigma}[+_0]=+_\sigma)$$
Terminology 2: The iteration we are talking about $-^{\circ n}$ can be defined recursively in the following way: given a function $f:X\to X$
$i)$ $f^{\circ 0}(\beta)=\beta$ or $f^{\circ 0}={\rm id}_X$
$ii)$ $f^{\circ n+1}(\beta)=f(f^{\circ n}(\beta))$ or $f^{\circ n+1}=f\circ f^{\circ n+1}$
My naive opinion is that if one is able to find a good space $\mathcal H$ such that $\Sigma$ is an operator then we could try to apply the powerful tools of operator theory.
This kind of point of view can be used for a larger class operation sequences. The idea of reducing the non-integer ranks problem ot a non-integer iteration problem is, again, as far as I know due to Henrik Trappmann [15](2008), the founder of the Tetration Forum . Some years later this idea was better developed by James Nixon (2011) with the concept of "meta-superfunctions" [16] who is still working on this point of view (see later).
To explain better this we have to first find what kind of map is or should be $\Sigma$, the map that increases the rank by one unit: the discourse is a bit long so I'll send you to one of my answer at MSE [17].
As you can read in my answer $\Sigma$ is closely related to the process of iterating a function, also called "taking the superfunction" in the case of $1$-ary functions and is also closely related to known problems as finding the solutions of Abel functional equations of the form $\chi(z)+1=\chi(f(z))$, Schröder's equations $s\cdot\Psi(z)=\Psi(f(z))$
A massive amount of research on finding/building unique superfunctions [20] was made and is still carried by D. Kouznetsov [18], [19] and you can find most of his work in this online enciclopedia [23].
Finding an unique $\beta$-based superfunction actually give us an "higher order" (because send functions to functions) function that maps the function $f(x)$ to the function $F(z)=f^{\circ z}(\beta)$
Definition 2 Given a function $f$ we define intuitively its $\beta$-based superfunction $F_\beta$ as the function that maps to every $z$ the $z$-th application of $f$ to $\beta$
$$F(z)=f^{\circ z}(\beta)$$
Proposition 1: The $\beta$-based superfunction of $f$ satisfies this equations
$i)$ $F_\beta(0)=\beta$
$ii)$ $F_\beta(z+1)=f(F_\beta(z))$
Definition 3 Given a suitable collection functions $H$ we define intuitively the $\beta$-based superfunction map as a function $\mathcal S:H\to H$ that maps to every $f$ its $\beta$-based superfunction $F_\beta$
$$\mathcal S_\beta:f\mapsto F_\beta$$
$$\mathcal S_\beta[F](z)=f^{\circ z}(\beta)$$
Is easy to see what this has to do with hyperoperations and with the $\Sigma$.
Lets define the sequence of "hyper-exponentiations"
Definition 4 We define the family $\{H_{b,s}\}_{b,s\in \Bbb N}$ of hyper-exponentiations as follows
$$H_{b,s}(n):=b+_s n$$
we have that $H_{b,1}(n)={\rm add}_b(n)=b+n$, $H_{b,2}(n)={\rm mul}_b(n)=bn$ and $H_{b,3}(n)=\exp_b(n)=b^n$
Proposition 2: From the definition 1 we have the following
$$H_{b,s+1}(n+1)=H_{b,s}(H_{b,s+1}(n))$$
In other words we have that the superfunction map is the map $\Sigma$ we are looking for because we have that every $(s+1)$-rank hyper-exp is the superfunction of the $s$-rank hyper-exp
$$\mathcal S[H_{b,s}]=H_{b,s+1}$$
At this point it makes sens to ask if finding the non-integers iterations of $\mathcal S_\beta$ really gives us non-integer ranks hyper-exponentiations functions for some bases $b$
$$\mathcal S_{\beta=1}^{\circ \sigma}[H_{b,2}]=H_{b,2+\sigma}$$
Remark 2: In the equation above I've setted $H_{b,2}$ and $\beta=1$ because for all the natural ranks $s\ge 3$ we have that $H_{b,s}(0)=1$ by definition.
Question 1: The real question is: It is possible to find the unique... real... non-integer iterations of $\mathcal S$?
As far as I know the answer to this question is still unknown or at least unknown to me, an amateur mathematician, even if some hot posts by the user JmsNxn appeared in the last two months on the Tetration Forum [21], [22].
References
1 - R.L. Goodstein, Transfinite Ordinals in Recursive Number Theory, The journal of Symbolic Logic Vol 12, No 4 (Dec. 1947), pp. 123-129
2 - Wikipedia, Hyperoperations - Notations
3 - K. A. Rubtsov, G. F. Romerio, Ackermann’s Function and New Arithmetical Operations. Manuscript cited in the bibliography of Stephen Wolfram’s book A New Kind of Science,(2003)
4 - A. Grzegorczyk, Some classes of recursive functions Rozprawy matematyczne, Vol 4, pp. 1–45. (1953)
5 - G. F. Romerio, Terminology Proposals for a Hyper operation Environment, uploaded at Tetration Forum
6 - D. Kouznetsov, Evaluation of holomorphic ackermanns, Applied and Computational Mathematics. Vol. 3, No. 6, 2014, pp. 307-314.
doi: 10.11648/j.acm.20140306.14
7 - MSE: *Does anything precede incrementation in the operator “hierarchy”?(2013)
8 - TetrationForum, JmsNxn, Extension of the Ackermann function to operator less than addition (2011)
9 -K. A. Rubtsov, G. F. Romerio, Progress Report on Hyper-operations, Zeration, Wolfram Research Institute, USA NKS Forum IV, (2007).
10 - K. A. Rubtsov, G. F. Romerio, New Notes On Zeration, Wolfram Research Institute, USA NKS Forum, (2014).
11 - C. Reale, Zeroth-rank operation and non transitive numbers., Text in Italian (2012)
12 - TetrationForum, G.F Romerio, Zeration (2008)
13 - TetrationForum, tommy1729, Zeration=Inconsistent? (2014)
14 - TetrationFrum, KingDevyn, Negative, Fractional, and Complex Hyperoperations
15 - TetrationFrum, User:bo198214 aka H. Trappmann, non-natural operation ranks (2008)
16 - TetrationFrum, User:JmsNxn aka J. Nixon, generalizing the problem of fractional analytic Ackermann functions (2011)
17 -MSE: Notation for function $+\mapsto \times$, MphLee's answer (2013)
18 - Dmitrii Kouznetsov, personal page at Institute fo Laser Science University of Electro-Communications, 1-5-1 Chofugaoka, Chofu, Tokyo 182-8585, Japan
19 -Dmitrii Kouznetsov, Research proposals: Superfunctions
20 -TORI enciclopedia , Page:Superfunction
21 - TetrationFrum, User:JmsNxn aka J. Nixon, Bounded Analytic Hyper operators (2015)
22 - TetrationFrum, User:JmsNxn aka J. Nixon, On constructing hyper operations for bases $b>\eta$ (2015)
23 - TORI Enciclopedia
$\Bbb R-\Bbb N$ is the set of the real numbers without the integer positive numbers...
– m_l Apr 21 '15 at 16:51
