I am working on a project where I need to find similar roles -- for example, Software Engineer, Soft. Engineer , Software Eng ( all should be marked similar)
Currently, I have tried using the Standard Occupational Classification Dataset and tried using LSA, Leveinstein and unsupervised FastText with Word Movers Distances. The last option works but isn't great.
I am wondering if there are more comprehensive data sets or ways available to solve this problem?? Any lead would be helpful!
You can calculate the text similarity using Transformers. With transformers, we can get better accuracies. Try the following code:
pip install sentence-transformers==1.2.1
from sentence_transformers import SentenceTransformer model = SentenceTransformer('distilbert-base-uncased')
sen = [ "Software Engineer", "Soft. Engineer" , "Software Eng", "Senior Software Engineer", ]
sen_embeddings = model.encode(sen)
from sklearn.metrics.pairwise import cosine_similarity #let's calculate cosine similarity for sentence 0: cosine_similarity( [sen_embeddings[0]], sen_embeddings[1:] )
If the similarity score is greater than 0.6 ( or 0.7), you can assume the texts to be similar.
Shrinidhi M
  • 411
