I got recently confused when I noticed that there exists 2 types of polytime reductions, which lead to 2 different concepts of NP-hardness.
This is well explained in the answer to this question: Can one show NP-hardness by Turing reductions?
While a Karp reduction is required to show whether a problem is NP-Hard or co-NP-Hard, with Cook (aka Turing) reductions one only shows that a problem is "Cook-NP-hard", in a sense which does not distinguish NP-hardness from co-NP-hardness. More precisely,
  • In a Karp reduction, you map each instance $I$ of Problem $A$ to an instance $f(I)$ of Problem $B$, where $f(I)$ can be computed in polytime, and such that $$I \text{ is a Yes-instance for $A$} \iff f(I) \text{ is a Yes-instance for $B$}.$$ If $A$ is (Karp-)NP-Hard, this shows that $B$ is (Karp)-NP-Hard, too. And if $A$ is (Karp-)co-NP-hard, this shows that $B$ is (Karp)-co-NP-Hard, too.
  • In a Cook-reduction, you assume that there exists a polytime procedure $F$ to solve Problem $B$, and you show that Problem $A$ could be solved by calling this procedure a polynomial number of times. If Problem $A$ is known to be NP-hard, this shows that $B$ is (cook)-NP hard, but this does not tell us anything about the membership of $B$ in (Karp)-NP-Hard or (Karp)-co-NP-Hard.
1) In my understanding, Karp reductions only apply to decision problems, while we can show that any kind of problem is Cook-NP-Hard, is that correct?
2) If I want to prove that a problem is NP-complete, is it enough to show that this problem is Cook-NP-hard, and then to show that this problem is in NP? Similarly is a problem is Cook-NP-hard and in co-NP, does it prove that this problem is co-NP-complete?
3) A perhaps equivalent formulation of this question is as follows: While there is a distinction between the notions of Cook- and Karp-NP-Hardness, is there a real distinction between the notions of Cook- and Karp-NP-Completeness?
guigux
  • 123
NP-hardness is a property of decision problems. It doesn't matter whether you define it using Karp reductions or Cook reductions.
NP-hardness and NP-completeness are defined using Karp reductions. If you prove that a problem is Cook-NP-hard, then it doesn't imply that it is Karp-NP-hard. Indeed, coSAT (the collection of unsatisfiable CNFs) is Cook-NP-hard but probably not Karp-NP-hard. Under reasonable hardness assumptions, there are even problems in NP which are Cook-NP-hard but not Karp-NP-hard. See for example Mandal, Pavan, and Venugopalan, Separating Cook Completeness from Karp-Levin Completeness under a Worst-Case Hardness Hypothesis.
Yuval Filmus
  • 280,205
  • 27
  • 317
  • 514
