I have a field in my data store which must take exactly 180 bits of information. Some users will choose to make this data encrypted, some won't, so some of those 180 bit fields will be ciphertext some will be plaintext. A boolean will indicate which one the user is using. The important thing here is that I need this field to be exactly 180 bits long.
However, a 128-bit cipher will mean I have to put in 256 bits in as plaintext, which is fine, just use a buffer string, but this means that the output is 256 bits when what is stored must be exactly 180 bits. And I can't simply cut off the ciphertext or that would mess up the decryption.
If you have a unique, unchanging identifier for each entry in your data store, you can use counter mode.
A nice thing about counter mode turns a block cipher into a stream cipher. No matter what the block size is, CTR mode encrypts an $n$-bit plaintext into an $n$-bit ciphertext.
In order to achieve that, CTR requires a unique counter value per block. Note: not just a unique counter value per message, but a unique counter value per block. The counter size is the same as the block size. In your case, you have messages that fit on two blocks, thus each message requires two counter values. If you have a unique identifier $k$ for each message, you can use $k$ and $k+1$ as the counter values for the two blocks (the second of which is partial) of the message.
Thus you need a 127-bit unique identifier for each message (128-bit block, minus one bit to distinguish the two blocks inside each message). The only security requirement for these 127 bits is that they are never reused for a given key. The initial counter value to encrypt a message is often chosen randomly, but this is not a requirement, just a convenience to ensure uniqueness. Of course, to decrypt the data, you need to be able to recover the unique identifier associated with each entry.
If your entries have some kind of unique identifier, which is often the case in databases, then you're set. Just remember that if you move data around or normalize it in a way that changes the identifiers, you will need to decrypt and reencrypt the data.
Some crypto libraries may present CTR mode through a function that randomly generates the initial counter value and prepends it to the message (so you'd input a 160-bit plaintext and get back a 288-bit ciphertext). Use a library that lets you specify the initial counter value (almost all implementations will increment the counter by 1 for each successive block, so pick initial counter values that are even, but you'll need to be aware of the endianness used by your library).
Keep in mind that encryption only gives you confidentiality, not integrity. In other words, someone who obtains the ciphertexts but not the key will not be able to find any information about the data; but if someone can inject fake ciphertexts or modify existing ciphertexts, the tampering cannot be detected. It is intrinsically impossible to detect tampering by cryptographic means in your scenario since there is no room for any redundancy.
Gilles 'SO- stop being evil'
  • 44,159
  • 120
  • 184
One approach is to use what is known as format-preserving encryption. For instance, you could use VIL mode or FFX mode.
I recommend you spend some quality time on Cryptography.SE and with some research literature to learn more about these schemes. e.g.,
However, I do see two serious red flags with your scheme:
  • There is no salt/tweak. This means that all instances of the field will be encrypted the same way: if the same input repeats twice, you'll get the same output both times. This is usually a bad mode, as it makes your scheme equivalent to ECB mode, which is notoriously a bad idea. Instead, I recommend you use a tweakable FPE scheme, and set the tweak to be some identifier that is different for each row (e.g., a primary key, a row number, etc.).
  • None of these schemes provide any authentication/integrity. The lack of authentication/integrity is a red flag. In my experience, most schemes that use encryption without authentication/integrity are subject to a range of non-obvious attacks.
Due to these red flags, I recommend you talk to a professional cryptographer if security is important in your domain. You're in tricky waters.
D.W.
  • 167,959
  • 22
  • 232
  • 500
The simplest solution is the following encryption procedure:
Encrypt the first 128 bits.
Encrypt the last 128 bits.
Decryption works the other way around:
Decrypt the last 128 bits.
Decrypt the first 128 bits.
Performance is $256/160 = 1.6$ times slower than AES. It's best to use two different keys for the two steps.
There is a slight problem with this procedure regarding data integrity: if the first 32 bits of the ciphertext are modified, then the last 32 bits of the resulting plaintext will stay the same. If this worries you, add an extra step:
Performance drops to $384/160 = 2.4$ times slower than AES. Again, it's best to use three different keys.
Yuval Filmus
  • 280,205
  • 27
  • 317
  • 514
