8
When I first heard of these things I was very fascinated as I thought it sets really a limit to mathematics and science in general. But how practically relevant are these things?
For the Halting Problem: Are there more than some artificially constructed cases, where one can't decide whether the algorithm will terminate or not?
For the Incompleteness Theorem: Are there more than some artificially constructed cases, where one can't prove/disprove statement?
I'm asking this because it seems that in most areas of science it doesn't really matter that there are such fundamental limitations. Are they even there? I'd like to know where this really sets a limit and where it is really relevant.
Raphael
  • 73,212
  • 30
  • 182
  • 400
Nocta
  • 221
The halting problem being undecidable has lots of practical relevance, here is a quick example:
Writing anti-virus software is hard: We can't decide whether a given piece of code is malicious because if we could we could decide the halting problem.
To see this take a piece of code which takes as input a Turing machine $M$ and an input word $w$ and does something malicious if and only if $M$ halts on input $w$. If we could decide whether a given piece of code were malicious then we could decide whether this piece of code was malicious but then we would be able to decide the halting problem, which we know we cannot do.
What this is saying is that there is no perfect anti-virus software, it can't be done. That doesn't mean we shouldn't try to write anti-virus sotware, just that we will never be able to write a perfect one. In fact any statement about deciding what programs do is undecidable (see Rice's theorem).
With respect to Godel's theorem, Goodstein's theorem is an example of a statement which is unprovable using the Peano axioms.
David Richerby
  • 82,470
  • 26
  • 145
  • 239
Sam Jones
  • 1,151
  • 17
there are quite a few "roughly practical/applied" contexts with active research where the halting problem plays a role:
  • automated theorem proving. proving theorems by computers runs into the same undecidability limits of the halting problem.
  • proving program termination for real programs is an area of research and shows up in eg compiler logic and program analysis.
  • Kolmogorov complexity attempts to study the theoretical limits of data compression algorithms. finding an optimal compression (in a certain sense, ie finding the smallest TM compressing a string) is undecidable.
  • undecidability shows up in some physical problems. eg dynamical systems.
  • a basic problem studied called "the busy beaver" problem. still theoretical but less abstract than the halting problem and studied in particular for its connection. researchers have attempted to resolve this for decades for "small" TMs with few states/symbols.
here is an related/interesting quote from a recent paper studying the busy beaver problem "problems in number theory from busy beaver competition" by Michel (p.3):
Actually, the halting problem for Turing machines launched on a blank tape is m-complete, and this implies that this problem is as hard as the problem of the provability of a mathematical statement in a logical theory such as ZFC (Zermelo Fraenkel set theory with axiom of choice). So, when Turing machines with more and more states and symbols are studied, potentially all theorems of mathematics will be met. When more and more non-halting Turing machines are studied to be proved non-halting, one has to expect to face hard open problems in mathematics, that is problems that current mathematical knowledge can’t settle.
in other words the halting problem actually encodes/encapsulates the challenge of attempting to prove new mathematical theorems in math/CS and therefore can be regarded as extremely deep/practical/applied in this sense. (however while some consider this observation obvious or trivial, this is also generally not a commonly held/voiced opinion.)
vzn
  • 11,162
  • 28
  • 52
I am answering one of your two questions, regarding the halting problem.
First, the undecidability of the halting problem does not state that you cannot decide whether a given TM does not halt. It states that there is no general algorithm that can decide that for all TM.
This is a statement about our models of what constitute computation. But, according to Turing-Church thesis, that is all we have to express compuation.
Regarding the relevance, it is based on artificially constructed Turing Machines. But then, all TM are pretty artificial and constructed only to assert some facts about computation. Whether some TM are more relevant than others in practice is pretty much as important a question as the sex of angels, or the number of them that can stand on a needle head.
The undecidability of the halting problem tells us that there are general questions that cannot be solved by a general technique applicable to all cases. What I mean by general question is a question depending on some parameters, where the answer is to be found for some values of the parameters.
Recall that the purpose of much of our mathematics is to find general techniques to solve a family of problems. A typical example is the resolution of equations. The undecidability of the halting problem tells us that this is not always possible.
For example, it can be used to show that there is no general technique to decide whether a context-free grammar is ambiguous.
However, you question is a valid one. It may be that a problem is undecidable because you just made it a bit too general. Possibly, by restricting it a bit, you can make it decidable for useful and still large enough subfamily.
I do not have a spectacular example in mind, but I am sure there must be some.
I recall one true case of a program analysis problem that was proved NP-complete (unless it was undecidable, I do not remember well). Against all advice, a PhD student decided to tackle it anyway. He was actually able to show that some restrictions on the problem, that did not matter much in practice, turned it into a very tractable problem, thus enabling the use of various program analysis and optimization tools.
babou
  • 19,645
  • 43
  • 77
