11
I have noticed that Slic3r offers a speed setting called "auto speed" meant to give a constant filament pressure at the extruder, which I believe could eliminate filament grinding issues at higher printing speeds.
According to the tooltip in Slic3r, auto speed is calculated from two parameters:
  • Maximum speed
  • Maximum volumetric speed
Maximum speed speaks for itself, but how can I calculate the maximum volumetric speed of my print?
Trish
  • 22,760
  • 13
  • 53
  • 106
Tormod Haugene
  • 4,022
  • 23
  • 40
Auto speed is calculated from maximum volumetric speed in mm3 per second. If you normally print at 80 mm/s, your extrusion width is 0.5 mm and you are printing 0.2mm high layers, your volumetric speed would be 80 * 0.5 * 0.2 = 8 mm3/s, which is the volume of plastic extruded by your printer every second when printing at that speed (not accounting for any die swell).
Tormod Haugene
  • 4,022
  • 23
  • 40
Ian Williams
  • 126
There's no fixed maximum volumetric speed that works for everyone, there's simply too much variables to account for. By using @Ian Williams explanation you can convert from volumetric to regular speeds but you still need to test what speed works best for your setup.
Just a few of the other variables affecting how fast material can come out consistently: temperature (nozzle & heat brake), extruder motor power, path friction between extruder and hotend, material compressibility, fluidity and glass transition temperature, ..
There are interesting topics on RepRap forums, like this one:
http://forums.reprap.org/read.php?262,654085
4levels
  • 121
